Thread Closed
convert concentration to dose?
Share Thread
Feb17-10, 10:16 AM   #1
How do you get from a concentration to an effective dose? For example, if you have 10-9 Ci/cm3 of tritium in a human body, then how do you get the effective dose to that body?
Thanks
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Feb17-10, 11:39 AM   #2
Using the Mass Activity Calculator in Nucleonica (www.nucleonica.net), 10-9 Ci of tritum corresponds to 37 Bq. Also from Nucleonica, the effective dose coefficient for ingestion for tritium is 1.8x10-11 Sv/Bq. Hence the dose is 37 x 1.8x10-11 Sv per cm3 = 57 x 10-11 Sv per cm3. To obtain the total dose you then need to multiply by the volume of the human body or that part which has been exposed- I'll leave this as an exercise! If the tritium intake is by inhalation, then the effective dose coefficient for inhalation must be used. This is 2.6x10-10 Sv per Bq i.e. considerably higher than that for ingestion.
Feb17-10, 12:33 PM   #3
I'm not sure I follow how time plays into this. Does this process give me the Sv per second or per disintegration? If you have a decaying source, you wouldn't just get a single dose. I guess what I'm looking for is the dose rate, sorry for the confusion.
Feb17-10, 12:54 PM   #4
Admin
Quote by Smed View Post
Thanks
One could integrate does rate per unit volume over time and get a does per unit volume, which of course assumes that all that is produced is absorbed. Of course, one would take into account the decay of the nuclide as well as the biological removal rate.
Feb18-10, 12:02 PM   #5
Good question. Actually the effective dose coefficients are denoted by e(50). The 50 refers to the following 50 years after incorporation. Sophisticated bio-kinetic models have been developed to account for the total radiation damage to the cells from the incorporation of a radionuclide. All known effects are accounted for e.g. biological half-life, presence of daughters etc. The relationship between the Dose and the Activity is given by
Dose (Sv) = e(50) x Activity (Bq)
From this value one can estimate the risk of cancer for example. Basically the unit Sievert (Sv) is the energy deposited in the tissue.
If you would like to calculate the dose rate this requires a different approach. From the activity in Bq, one obtains the number of disintegrations per second. In each disintegration, a 20 keV electron is emitted. This electron is then absorbed in the tissue causing damage. So the rate of energy released is
Energy emission rate (keV/s) = Activity (Bq) x 20 keV
with units keV per second. This needs to be converted into joules i.e.
Energy emission rate (Joule per second) = activity x 20 x 1000 x 1.6e-19
For the activity of 37 Bq, this corresponds to
Energy emission rate (joule per second)= 37 x 20 x1000 x 1.6e-19 = 1.2 E-16
Since the "quality factor" for electrons is one, this means that the dose rate is equal to the energy emission rate i.e.
Dose Rate = 1.2 E- 16 Sieverts per second.
This is an extremely small dose rate.
For further information, I refer you to the relevant Nucleonica wiki article...
http://www.nucleonica.net/wiki/index..._%26_Shielding
Thread Closed
Similar discussions for: convert concentration to dose?
Thread Forum Replies
How does a dose rate meter determine dose with only a GM tool? General Physics 9
CT dose information Medical Sciences 3
Daily dose of idiocy General Discussion 14
Dose Randome exist? General Math 26
