Distinction between this geometric example of a Diffeomorphism & a Homeomorphism
The discussion clarifies the distinction between homeomorphisms and diffeomorphisms using geometric examples. A homeomorphism, exemplified by a doughnut and a coffee cup, requires only continuous deformation, while a diffeomorphism, illustrated by transformations of a rubber cube, necessitates differentiability. The key difference lies in the requirement for differentiability in diffeomorphisms, which is not present in homeomorphisms. For instance, transforming a cube into a sphere is a homeomorphism but not a diffeomorphism due to the cube's corners.
  • Understanding of topological concepts such as homeomorphism and diffeomorphism
  • Familiarity with geometric transformations and their properties
  • Basic knowledge of calculus, particularly differentiability
  • Concept of continuous functions in topology
  • Study the formal definitions of homeomorphisms and diffeomorphisms in topology
  • Explore examples of continuous and differentiable transformations in geometric contexts
  • Learn about the implications of differentiability in various dimensions
  • Investigate the role of topology in advanced mathematical theories and applications
Mathematicians, students of topology, and anyone interested in understanding the nuances of geometric transformations and their applications in higher mathematics.
damnedcat
when I first learned about homeomorphic sets, I was given the example of a doughnut and a coffee cup as being homeomorphic since they could be continuously deformed into each other. fair enough.
Recently I heard another such example being given about diffeomorphisms: "Take a rubber cube. Loosly, Anything you can do to this cube without tearing it or glueing two parts together is a diffeomorphism. You can stretch it, rotate it, twist it, or do each of these things at different points. In other words it's the most general kind of transformation of the cube that is "nice" in some sense."
Now these two geometric examples seem to be essentially the same thing, Am I missing some subtle difference between these examples?
Do the apparent similarities in the geometric examples lie in the fact that homeomorphic surfaces are diffeomorphic in 1,2 or 3 dimensions?
(without getting overly techical and sticking to the geometric interpretation)
A homeomorphism need only be continuous; whereas a diffeomorphism needs to be differentiable. So for example, changing a cube into a sphere is a homeomorphism, but not a diffeomorphism, because the cube has corners that you can't eliminate in a differentiable way.
  • · Replies 69 ·
14K
  • · Replies 45 ·
17K
  • · Replies 52 ·
10K
  • · Replies 51 ·
9K
  • · Replies 92 ·
14K
  • · Replies 48 ·
