Difference in Magnitudes between two densities
The discussion centers on calculating the difference in magnitudes between the densities of water (0.995 g/cm³) and sodium chloride (NaCl) (1.0499 g/cm³). The user correctly identifies that the difference is found by subtracting the density of water from that of NaCl, resulting in a magnitude of 0.0549 g/cm³. However, there is confusion regarding the density of NaCl, with suggestions that it may be higher than 1.05 g/cm³, potentially indicating a misunderstanding related to NaCl solutions rather than pure NaCl.
  • Understanding of density and its calculation
  • Familiarity with the properties of water and sodium chloride
  • Basic graphing skills for visualizing mass and volume relationships
  • Knowledge of solution concentrations and their effects on density
  • Research the density of pure sodium chloride versus sodium chloride solutions
  • Learn about the factors affecting the density of solutions
  • Explore the concept of magnitude in physics and its application to density
  • Investigate methods for accurately measuring density in laboratory settings
Students studying chemistry, particularly those focusing on solution properties, as well as educators seeking to clarify concepts related to density and its calculations.
Roma19
the question is to find the difference in magnitudes between the density of water which 0.995 and density of NaCl which is 1.0499
when speaking about the difference, I simply minus 1.0499 from 0.995
since magnitude means distance and displacement . I found the slopes of mass and volume of my graph which gave me the densities of both solutions
just want to know if I am on the right track
Can you post the complete and correct text? It does not make too much sense as it is.
And density of NaCl is not 1.05 but something over 2. Maybe it's about a NaCl solution?
  • · Replies 17 ·
