How Can Viscous Drag Affect the Velocity of a Sliding Block?
The discussion revolves around a physics problem involving a block sliding on a lubricated surface, experiencing viscous drag that varies with speed. The problem requires finding the velocity as a function of time and displacement as a function of time, particularly focusing on the case where the drag coefficient is defined by a power law.
  • Mixed
  • Participants explore the relationship between velocity and time, with some attempting to derive expressions for displacement and velocity based on the given drag force. Questions arise regarding the validity of derived equations and the implications of certain terms leading to infinite speed.
There is an ongoing examination of the derived equations, with some participants questioning the correctness of the expressions for displacement and velocity. Guidance is provided regarding the treatment of signs in equations and the implications of physical constraints, such as the unphysical nature of negative time.
Participants note discrepancies in the derived equations and emphasize the importance of careful algebraic manipulation. The discussion reflects a focus on ensuring that the results align with physical expectations, particularly in terms of the behavior of the block as it slides to a stop.
Mechdude
heres a problem i working on
a block slides on a horizontal surface which has been lubricated with a heavy oil such that the block experiences a viscous drag
resistance in the opposite direction to the velocity and that varies with speed according to:
[tex]F\left( v\right) =-c\,i\,{v}^{n}[/tex]
if the initial speed is [itex]v_0[/itex] at [itex]t=0[/itex]
a) find [itex]v[/itex] as a function of time [itex]t[/itex]
which iv found ;
[tex]{\left( {v_o}^{1-n}+\frac{c\left( n-1\right) \,t}{m}\right) }^{\frac{1}{1-n}}[/tex]
b) For [itex]n = \frac{1}{2}[/itex] find the displacement x[itex]\vec{i}[/itex] as a function of t: i is the unit vectoer in x direction. .
which iv found
[tex]x- x_o = \frac{12\,{m}^{2}\,t\,vo+6\,c\,m\,{t}^{2}\,\sqrt{vo}+{c}^{2}\,{t}^{3}}{12\,{m}^{2}}[/tex]
c) show that for [itex]n = 1/2[/itex] , the block will not travel further than [tex]\frac{2mv_o^{\frac{3}{2}} }{3c}[/tex]
now this is the sucker that will not work out. the answers for a and b are as given in the
assignment sheet, so they are ok.
give me a clue on how to do this
I really don't think b) can be right. For one thing, x-x0 increases without bound as t increases, which implies the block will eventually reach infinite speed.
Use
[tex]a=v\frac{dv}{dx}[/tex]
and find v(x).
correction
the second equation that i found has a sign problem on the second term compared to the solution provided
[tex]x- x_o = \frac{12\,{m}^{2}\,t\,vo-6\,c\,m\,{t}^{2}\,\sqrt{v_o}+{c}^{2}\,{t}^{3}}{12\,{m}^{2}}[/tex]
OK, do it your way. Can you find the velocity as a function of time from your expression? Can you find at what time that velocity goes to zero?
so from the espression for [itex]f(v)= -cv^n[/itex]we can get using[itex]f=ma[/itex] one of Newtons laws
[itex]a= dv/dt=\frac{-cv^n }{m}[/itex]
and a little separation of variables,
[tex]v(t)= {\left( {v_o}^{1-n}+\frac{c\left( n-1\right) \,t}{m}\right) }^{\frac{1}{1-n}}[/tex]
the integration was done much like that of obtaining Newtons equations of motion, from 0 to t, and [itex]dv = v -v_o[/itex] but since the force is variable
the acceleration was not treated as a constant.
integrating this wrt time again we get
[tex]x-x_o= \frac{t\,\left( 12\,{m}^{2}\,v_o-6\,c\,m\,t\,\sqrt{v_o}+{c}^{2}\,{t}^{2}\right) }{12\,{m}^{2}}[/tex]
and we get this expression from v(t) at n=1/2
[tex]v(t)={\left( -\sqrt{vo}-\frac{c\,t}{2\,m}\right) }^{2}[/tex]
when the block stops moving v will be =0 hence we can solve for t at v=0
[tex]t= \pm \frac{2\,m\,\sqrt{v_o}}{c}[/tex]
inserting this into the equation for displacement x below that we found
[tex]\frac{t\,\left( 12\,{m}^{2}\,v_o-6\,c\,m\,t\,\sqrt{v_o}+{c}^{2}\,{t}^{2}\right) }{12\,{m}^{2}}[/tex]
we get after a little algebra (for the negative t, il try the positive t later)
[tex]-\frac{14\,m\,{v_o}^{\frac{3}{2}}}{3\,c}[/tex]
regards
mechdude.
How do you get two times from
[tex] 0={\left( -\sqrt{vo}-\frac{c\,t}{2\,m}\right) }^{2}[/tex]
*** Added on Edit ***
Also, negative times are unphysical. Check your signs along the derivation of the expression above.
Sorry, my bad, the expresion on the right is squared, so there's both negative and positive roots, but negative times are unphysical , il consider the positive root.
How do you get a positive root out of
[tex] <br /> 0={\left( -\sqrt{vo}-\frac{c\,t}{2\,m}\right) }^{2}<br /> [/tex]
Check the math that got you to this point.
starting from the expression for velocity;
[tex]v(t)= {\left( \sqrt{v_o}-\frac{c\,t}{2\,m}\right) }^{2}[/tex]
and expanding it [tex]v(t)= v_o-\frac{c\,t\,\sqrt{v_o}}{m}+\frac{{c}^{2}\,{t}^{2}}{4\,{m}^{2}}[/tex]
now if we set v to zero (when it finally stops)
[tex]0 = v_o-\frac{c\,t\,\sqrt{v_o}}{m}+\frac{{c}^{2}\,{t}^{2}}{4\,{m}^{2}}[/tex]
and solve for t: using the quadratic formula:
[tex]x=-b \pm \frac{\sqrt{{b}^{2}-4\,a\,c}}{2\,a}[/tex]
[tex]t=\frac{2\,m\,\sqrt{v_o}}{c}[/tex]
if we substitute this time into the expression for displacement:
[tex]x-x_o= \frac{12\,{m}^{2}\,t\,v_o-6\,c\,m\,{t}^{2}\,\sqrt{v_o}+{c}^{2}\,{t}^{3}}{12\,{m}^{2}}[/tex]
we then get [tex]x-x_o = \frac{2\,m\,{v_o}^{\frac{3}{2}}}{3\,c}[/tex]
which is what was required.
That's better. Note that in the previous postings you had a minus sign in front of both terms between parentheses. Also, it is much quicker to take the square root on both sides
[tex]0=\pm {\left( \sqrt{v_o}-\frac{c\,t}{2\,m}\right) }[/tex]
which clearly has one solution
[tex] t=\frac{2\,m\,\sqrt{v_o}}{c} [/tex]
thanks, i was not exactly cautious while working the problem,
regards.
