Solving the Spinning Wheel Problem - Jonathan
  • Context: Undergrad
  • Thread starter Thread starter zarcon
    Spinning Wheel
The discussion centers on the physics of rotating objects, specifically the behavior of a spinning bicycle wheel when it interacts with the ground. When a spinning wheel bounces, it translates forward due to the frictional force acting perpendicular to its center of mass, which induces both rotation and translation. The key takeaway is that applying a force away from the center of mass generates torque, leading to both rotational and translational motion, thereby increasing kinetic energy. This phenomenon does not violate any physical laws, as the work done on the object increases with the distance over which the force is applied.
  • Understanding of Newton's laws of motion
  • Familiarity with concepts of torque and rotational dynamics
  • Basic knowledge of kinetic energy and work-energy principles
  • Experience with free body diagrams and force analysis
  • Study the principles of torque in rotational motion
  • Learn about the relationship between force, work, and energy in physics
  • Explore the dynamics of rigid body motion
  • Investigate the effects of friction on rotating bodies
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of rotating objects and their interactions with surfaces.
zarcon
Hi All! This is my first real post here.
I have a pretty basic question regarding rotating objects and the manner in which the rotation becomes a translation.
If I drop a bicycle wheel against the ground, it bounces back toward my hand. But if the wheel is spinning as it falls, it will move forward after it bounces.
I know (think) this is because of the opposing friction from the contact of the spinning wheel and the ground, but a diagram of the forces would show a frictional force perpendicular to the wheel's center of mass. Shouldn't this then be a completely rotational force?
If the wheel is floating perfectly still in space and a force is applied perpendicular to the wheel's center of mass, it will cause the object to spin without any linear translation, like a basketball on the end of somebody's finger, or a plate on a stick, right?
So a perpendicular force applied opposite to the direction an object is rotating will cause it to move in the direction of the force? Is that right? How would that be calculated?
Thanks! Hope I made my question understandable. Anything to point me in the right direction would be really appreciated.
Jonathan
This is something that takes a bit getting used to, but there's no such thing as 'only a rotational force'. I know, it's completely counter-intuitive, but if you apply a force so that it hits the center of mass, then it produces a translation but no rotation. However, if you apply this same force at a different point such that it induces a torque and a rotation, it will still product the same translation!
This is NOT a violation of any laws. You may be thinking "but isn't there also an increase in kinetic energy, due to the fact that the object is rotation AND translating". That would be a true statement. However, when you apply a force away from the center of mass, the force is applied over a greater distance as the object rotates, and subsequently the increase in kinetic energy comes from the fact that you really did increase the amount of work you did on the object.
  • · Replies 22 ·
  • · Replies 19 ·
  • · Replies 60 ·
