What Is the Magnetic Force on a Proton Moving in a Magnetic Field?
The magnetic force on a proton moving in a magnetic field is determined using the equation F=q(v x B). In this scenario, the proton moves in the -y direction with a velocity of 3.01x10^7 m/s while the magnetic field points in the +y direction with a magnitude of 5.0 T. The cross product of the velocity and magnetic field vectors results in a zero vector, confirming that the magnetic force is indeed zero. This conclusion is based on the understanding that anti-parallel vectors yield a cross product of zero.
  • Understanding of vector cross products
  • Familiarity with magnetic force equations
  • Knowledge of basic physics concepts regarding motion and magnetic fields
  • Ability to perform vector operations in three-dimensional space
  • Study the properties of vector cross products in detail
  • Learn about the Lorentz force law and its applications
  • Explore examples of magnetic forces on charged particles in various fields
  • Investigate the implications of magnetic fields in particle physics
Students studying physics, particularly those focusing on electromagnetism, as well as educators seeking to clarify concepts related to magnetic forces and vector operations.
TheDoorsOfMe
Proton moving in -y direction with a magnetic field pointing in the +y direction with a manitude of 5.0 T. The proton has a velocity of 3.01x10^7, What is the magnitude and direction of the magnetic force.
F=q(v x B)
The answer I think is either 0 or 1.5x10^8.
I say it might be zero cause the cross product of anti-parallel vectors is zero right? Or I say its 1.5x10^8 because I just plugged into the above equation a solved. Which one is it? Or is it neither.
F=q(v x B)
Id take your first answer, zero.
By the looks of it, you have taken cross product to be the same thing as scalar multiplication, which is not true. Have a look at these links for more about the vector cross product:
http://cnx.org/content/m13603/latest/
http://tutorial.math.lamar.edu/Classes/CalcII/CrossProduct.aspx
If you were to define the velocity vector as <0, 3.01x10^7, 0> m/s and the magnetic field vector as <0, -5, 0> T, and then proceeded to apply the cross product operation, you would end up with a zero vector, which would agree with your first answer.
  • · Replies 29 ·
