What are Pipe Minor and Major Diameters in Tapered Whitworth Threads?
  • Thread starter Thread starter optics.tech
    Reading Table
The discussion clarifies the definitions of Pipe Minor Diameter, Pipe Major Diameter, and Tapping Drill Size in relation to Tapered Whitworth Threads. The Major Diameter refers to the largest diameter of the thread form, while the Minor Diameter is associated with the internal diameter of the pipe, not the thread form itself. The Tapping Drill Size is the drill bit size required to create a hole suitable for tapping a female connection. Specific measurements, such as the 3mm internal diameter for the 1/16 nominal size, are highlighted as critical for understanding these terms.
  • Understanding of Tapered Whitworth Threads
  • Familiarity with pipe dimensions and specifications
  • Knowledge of tapping and drilling processes
  • Access to Machinery's Handbook for reference
  • Research Tapered Whitworth Thread specifications in detail
  • Learn about the relationship between pipe dimensions and thread forms
  • Explore the process of selecting appropriate Tapping Drill Sizes
  • Investigate the differences between tapered and straight thread forms
This discussion is beneficial for mechanical engineers, machinists, and anyone involved in pipe fitting or thread manufacturing who needs to understand the specifics of Tapered Whitworth Threads.
optics.tech
http://www.accuratescrew.com/TechTips/images/tip8_screw1a.gif should help. Also, the tapping drill size is the size drill used to produce a hole which can be tapped for a female connection.
Tapered Whitworth threads? Hoo. That's something you don't see every day in my parts. I can only guess as to what is referenced, but it appears that, at some gauge point determined in the thread spec, the major and minor diameters are still of the pipe thread. The tap drill size is just that, it is the drill bit size you predrill the hole for to prepare for running the desired tap through.
One of our Brit friends will have to verify that. I can't find anything specific to this thread form in Machinery's under this title. It is probably referenced under a different description and I just haven't found it yet. I'll keep looking.
EDIT: I found it in Machinery's. The Major diameter is definitely the major diameter of the thread form. The pipe minor diameter has me a bit stumped. It is not the minor of the thread form. For example, for the 1/16 nominal size (the first in the list) the minor diameter of the thread form is listed as 6.561. In that table it is listed as 3. That must mean that the pipe ID is 3mm. Unfortunately Machinery's doesn't go into a lot of detail for the tapered thread form as it does for the straight thread form. I will still have to yield to one of our European members for some assistance on this one. Good Luck.
13K
12K
  • · Replies 65 ·
13K
15K
