Qualitative Anion Analysis in General Chemistry Course
The discussion focuses on qualitative anion analysis in a General Chemistry course, specifically reactions involving potassium iodide (KI) and potassium chromate (K2CrO4) with sulfuric acid (H2SO4). The user struggles to balance the equations and understand the role of ions in the reactions. For KI, the proposed balanced equation is 2KI(s) + H2SO4(aq) -> I2(g) + H2S(g) + 2K+(aq) + 2O2(g), though it requires adjustments for charge balance and product states. For K2CrO4, the user suggests 2K2CrO4(s) + 2H+(aq) -> Cr2O72-(aq) + H2O(l) + 4K+(aq), recognizing the need to account for spectator ions and the dissociation of the solid in solution.
  • Understanding of acid-base reactions and their products.
  • Knowledge of ionic compounds and their dissociation in solution.
  • Familiarity with balancing chemical equations, including charge balance.
  • Basic concepts of redox reactions and their identification.
  • Study the principles of balancing redox reactions in acidic solutions.
  • Learn about the role of spectator ions in chemical reactions.
  • Explore the properties and reactions of common anions in qualitative analysis.
  • Review the concepts of oxidation states and their application in reaction balancing.
Chemistry students, educators, and anyone involved in qualitative analysis of anions in laboratory settings will benefit from this discussion.
Yanick
Hi guys and gals. I'm new to the site and have been reading and learning a lot from here. I can't believe I didn't know about this place before. Anyway I'm having a pretty difficult time with a certain reaction that I had to do in my General Chemistry lab. Any help would be appreciated!
We were asked to add H2SO4(aq) to a bunch of different salts, watch for the physical manifestations of the reactions (if there were any) and then write a balanced equation/net ionic equation.
There are actually 2 that are giving me problems and I've been sitting here staring at them for about an hour now. I just can't seem to get it right.
1. KI(s) + H2SO4(aq)
2. K2CrO4(s) + H2SO4(aq)
I just can't get an equation that seems right to me.
1. according to the lab manual, just adding the sulfuric acid to the potassium iodide at room temp you should see effervescense and a darkening of the solid, then you should smel hydrogen sulfide and see violet fumes of Iodine.
So my take on it is as follows;
The balancing seems to work out for this one but I am unsure if I have the states correct and if that is really the appropriate equation (I did a google search and saw stuff like SO2 as a possible product)
2. Our instructor provided us with a formula on the board as follows;
2CrO42- + H2O -> Cr2O72- + 2OH-
so my thought was that because K2CrO4 is an ionic compound it should dissociate upon addition of solvent but I just can't make the reaction work out on paper. It seems from what the instructor said the chromate should become dichromate and there should be a hydroxide product but, for the life of me, I can't figure out what the acid is doing in the reaction. It seems like whatever available water in the acid solution is reacting with chromate but then what happens to the hydrogen and sulfate ions? Are they spectators? I really just can't wrap my head around this problem. I feel as though there is some kind of information, or key concept, that I have not been taught yet because I just can't come up with an answer that sits right with me.
Thank for any help you guys can offer!
First reaction - charges are not balanced, it is not only about balancing atoms. And there will be no free oxygen between products, more like water.
As for the second - try to add H+ on both sides of the reaction. After all you used acid.
I may be thick in the head but I have no clue how I can possibly balance the charges with what I'm given here. Something tells me that this is a reaction which I cannot workout with the level of Chemistry education I have been given thus far. The instructor did mention that we wouldn't be able to work out some of the reactions because they are redox, and I'm getting the inkling that this is one of those.
Well the thing that bothers about this one is that we are starting with K2CrO4 as a solid. The reaction that he put on the board is okay if you have the salt in a solution whereby the potassium can just be a spectator. So this is my shot in the dark upon, but I'm not hopeful
I left out the sulfate ion as a spectator, both sides have same charge (+2). It looks okay to me. Any opinions?
34K
