Thread Closed
Theory Question about Electric Potential Energy
Share Thread Thread Tools
Feb20-10, 01:13 PM   #1
I'm having a little bit of trouble understanding the concept that the potential electrical energy between two opposite charges is negative while between like charges it is positive.
Can someone please explain in detail why this is so? Thanks in advance.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Feb20-10, 02:23 PM   #2
I think you need to reformulate your question as it doesn't tie in with the facts.
The electrical potential energy (of a unit positive charge, which is how PE is defined here) between two like charges is positive if the charges are positive, and negative if the charges are negative.
Between two opposite charges it can be either positive or negative depending on where you are in the field in relation to the two charges.
The definition of electrical potential energy at a point is in terms of the work done bringing a unit positive charge from infinity to that point.
Feb20-10, 02:28 PM   #3
In generally the work expended against a force field is positive.
The work expended towards a force field is negative.
With this arbitrary definition we obtain the result you have stated.
So if you have a charge [tex]q_1>0[/tex] at the origin and a charge [tex]q_2<0[/tex] at [tex]r_2[/tex] then the work you must expend on [tex]q_2[/tex] to pull the charge from infinity to [tex]r_2[/tex] is
[tex]W = V(r_2) = - q_2 \, \int \limits_{\infty}^{r_2} \mathrm{d} \vec r ~ \vec E_1(r) = q_1 \,\int \limits_{\infty}^{r_2} \mathrm{d} \vec r ~ \vec \nabla \phi_1(r) = q_1 \Bigl[\phi_1(r_2) - \phi_1(\infty) \Bigr] = q_2 q_1 \frac{1}{4\pi \varepsilon_0 r_2}[/tex]
The fact that [tex]W<0[/tex] (with the above definition of [tex]q_2, q_1[/tex]) shows, that you have to expend the work towards the force field to bring the charge [tex]q_2[/tex] from infinty to [tex]r_2[/tex] (the force between opposite charges is attractive).
That's it! I hope i could help you!?
Feb20-10, 02:42 PM   #4
Quote by Stonebridge View Post
I don't agree with you! Compare electric potential with electric potential energy. Because two like charges are always repulsing each other the electric potential energy between them is always positive (cause you have to expend work against the force field to get one charge from infinity to any position).
Feb20-10, 03:19 PM   #5
Quote by saunderson View Post
Not if the charges are negative.
Electrical potential refers to the potential energy of a unit POSITIVE charge.
Feb20-10, 03:42 PM   #6
zerobladex asked for Electric Potential Energy and not for Electrical potential!
[tex]V(r) = E - T ~ \ne ~ q_{+} \, \phi(r) \qquad \mbox{with} ~ q_{+} ~ \mbox{as unit POSITIVE charge}[/tex]
where [tex]T[/tex] is the kinetic energy of the particle and [tex]E[/tex] the total energy.
Feb21-10, 05:01 AM   #7
I interpreted the words "between two positive charges", to be referring to a point between the two charges; and the question to be asking about the potential energy of some charge at that point. Apologies to all.
Thread Closed
Thread Tools
Similar Threads for: Theory Question about Electric Potential Energy
Thread Forum Replies
Question on Electric Potential Energy Introductory Physics Homework 6
Electric Potential Energy Question Introductory Physics Homework 5
Electric potential and electric potential energy question... Introductory Physics Homework 1
Electric Potential/Electric Potential Energy question... Introductory Physics Homework 3
Electric Potential/Energy question Introductory Physics Homework 2
