Connect electric guitar pickup to PC
Connecting an electric guitar pickup directly to a PC requires proper wiring and understanding of the sound card's input configuration. The user successfully wired the pickup to a cable for the sound card but encountered issues with low signal reception. Key troubleshooting steps include ensuring the correct contact on the stereo plug is used and verifying that the microphone input is not muted in the sound settings. The microphone input must be selected and set to maximum volume for optimal performance.
  • Understanding of electric guitar pickups and their wiring
  • Familiarity with PC sound card configurations
  • Knowledge of audio settings in Windows Control Panel
  • Basic troubleshooting skills for audio devices
  • Research proper wiring techniques for electric guitar pickups
  • Learn about different types of audio inputs on sound cards
  • Explore audio troubleshooting methods in Windows
  • Investigate audio interface options for better guitar connectivity
Musicians, audio engineers, and hobbyists looking to connect electric guitar pickups to PCs for recording or amplification purposes.
bar_ts
Hello,
I would like to connect my guitar pickup directly to my PC, is it possible?
I've wired an electric guitar pickup to a cable, which plugs directly to my sound card (where a microphone ought to be plugged):
Sound Card -> Cable -> Electric Guitar Pickup.
But it does not work properly. My PC almost does not receive any data - you can only notice it, when you strongly tap a massive iron on the pickup magnets (such as scissors).
It is important to add, that when I plug a standard electric guitar to my sound card (with a similar cable which I am now using), it works perfectly.
Please, Could anyone tell me what am I doing wrong?
Thank you so much in advance.
Do you already know that one of the connections on a stereo plug used for PC microphones is actually a power outlet, not a microphone input?
This also means the input is not stereo.
You need to connect to the contact that goes to the tip of the plug, not the one that goes to the ring around this tip.
Also check that the microphone input is not muted.
To do this go to START then CONTROL PANEL then SOUNDS AND AUDIO DEVICES
Then find the AUDIO section and look for microphone recording volume. (This may vary with your sound card).
Check that the microphone is selected, its volume is maximum and the mute square is not marked.
  • · Replies 25 ·
  • · Replies 165 ·
12K
  • · Replies 21 ·
  • · Replies 23 ·
