Calculating Wave Pulse Travel Time for an 80ft Nylon Rope
The discussion revolves around calculating the travel time of a wave pulse along an 80 ft nylon rope under a tension of 3000 lb, considering the rope's weight of 6 lb. Participants are exploring the relationship between tension, linear density, and wave speed.
  • Participants discuss the concentration of mass at the center of the rope and its implications for wave propagation. There is a focus on using the formula for wave speed and the need to determine linear density from the rope's weight and length. One participant expresses frustration over incorrect calculations and seeks clarification on the mass conversion.
Some guidance has been offered regarding the calculation of linear density and the application of the wave speed formula. However, there is no consensus on the correct approach, as one participant continues to struggle with their calculations and seeks further assistance.
Participants are working under the constraints of the problem's parameters, including the tension and weight of the rope. There is a discussion about the implications of mass on wave speed, which may affect the interpretation of the problem.
daisyi
A nylon rope of length 80 ft. is under a tension of 3000 lb. The total weight of this rope is 6 lb. If a wave pulse starts at one end of this rope, how long does it take to reach the other end?
Think of the mass (6lb) as being concentrated at the center of mass of the rope--at the geometric center in this case...
Cheers
Vivek
What good will that do?
The speed v of a pulse along a cord under tension [itex]\tau[/itex] and with linear density [itex]\mu[/itex] is given by:
[tex]v = \sqrt{\frac{\tau}{\mu}}[/tex]
To evaluate this for v, you need to know the other two variables. You were already given the tension, now you need to find the linear density. The linear density is the mass divided by the length.
You can find the mass from the weight (which you were given). Divide the mass by the length, substitute that for [itex]\mu[/itex] and the given tension for [itex]\tau[/itex], and you know how fast the pulse is travelling.
Solve displacement = velocity * time for time, plug in the value you just calculated for velocity and the length of the rope for displacement, and you're done.
Zorodius, your solution assumes that the mass of the string does not affect the overall motion. And I believe his problem was to figure out what role the mass has to do in that equation (which you answered). If I cut out the line mentioning the mass of the string and converted the problem into one where the tension and the linear density are given then it would take all the insight out of problem. Then it would just involve plugging the given values into [tex]v_{phase} = \sqrt{\frac{T}{\mu}}[/tex].
Of course, eventually we would all have used the formula for phase velocity that you posted, but my idea was to let him understand what he should do instead of giving him the solution rightaway. Besides, he didn't even send in his solution first (seeing which how we could have helped him better by helping him understand).
Anyways, you have correctly answered the problem and I have nothing against the solution :smile:
Cheers
Vivek
thanks for both of your help. The problem is that I already tried that (sorry I didn't put that there earlier, I was very frustrated at that point). But I am still coming up with the wrong answer. I keep getting 2.27 seconds...
so the mass = 6*32.2 = 193.2
and then to find u: 193.2/80 = 2.42
and then the velocity = sqrt(3000/2.42) = 35.2
so the time = 80/35.2 = 2.27 seconds.
grrr...what's going wrong here? :frown:
the problem is that mg=weight--->m=weight/g, and inthis case m=6/32.
I hope this helps
