How Is Work Calculated in Gravitational Fields?
The discussion centers on calculating work done in gravitational fields using Newton's Law of Gravitation, specifically the formula F = Gm1m2/r². The user attempts to derive the work needed to move one mass from distance r=a to r=b, initially calculating W = Gm1m2/(b-a). However, the correct expression for work is W = Gm1m2(1/a - 1/b), which accounts for the variable nature of gravitational force. The conversation highlights the importance of understanding calculus in solving such problems, as the force is not constant during the displacement.
  • Newton's Law of Gravitation
  • Basic calculus concepts
  • Understanding of force and displacement
  • Knowledge of gravitational constant (G)
  • Study the derivation of work done by variable forces
  • Learn about potential energy in gravitational fields
  • Explore calculus applications in physics
  • Review problems involving gravitational interactions
Students studying physics, particularly those focusing on mechanics and gravitational forces, as well as educators looking to clarify concepts related to work and energy in gravitational fields.
3.141592654
Newton's Law of Gravitation states that two bodies with masses m1 and m2 attract each other with a force:
[tex]F=\frac{Gm_{1}m_{2}}{r^2}[/tex]
where r is the distance between the bodies and G is the gravitational constant. If one of the bodies is fixed, find the work needed to move the other from r=a to r=b.
[tex]W=F*x[/tex]
[tex]x=r[/tex]
[tex]W=\frac{Gm_{1}m_{2}}{r^2}r = \frac{Gm_{1}m_{2}}{r}[/tex]
[tex]r=b-a[/tex]
[tex]W=Gm_{1}m_{2}(\frac{1}{b-a})[/tex]
The answer states that [tex]W=Gm_{1}m_{2}(\frac{1}{a}-\frac{1}{b})[/tex]. Did I make a mistake in setting up the problem?
Two bodies are attracting each other. If you want to take on body away from the other, then the displacement and the force are in the opposite direction.
So W = F*x*cos(theta). Here what is theta?
It seems that you have not learned calculus
The force here is not a constant,so you can't just use W=F*x
  • · Replies 17 ·
