Faster-than-light experiments at home?
The discussion revolves around proposed experiments and thought experiments related to the concept of faster-than-light (FTL) speeds, exploring various scenarios and interpretations within the context of physics. Participants examine the implications of visual phenomena, such as laser pointers and moving objects, and how they might suggest FTL motion, while also addressing the limitations and conditions of these claims.
  • Some participants propose using a laser pointer aimed at the moon to create the illusion of moving the dot faster than light by flicking the wrist quickly.
  • Others argue that for the dot to be seen moving faster than light, the wrist would need to be flicked at light speed, thus not violating the speed of light limit.
  • One participant suggests that the dot is not an object but an intersection, and that with a fast enough spinning mirror, a dot could appear to move faster than light.
  • Another participant introduces the idea of using a laser pointer to arc across the sky between distant stars, suggesting that while the laser can be pointed quickly, the light itself takes time to reach the stars.
  • Some participants discuss the use of a rotating mirror setup in laboratory experiments to measure the speed of light, noting that it effectively demonstrates the principles involved.
  • A participant raises the possibility of an illusion of FTL motion when observing a star moving towards Earth at an angle, suggesting that light from previous positions could create a misleading perception of speed.
  • Another participant counters this by mentioning the Doppler effect, which would cause a blue shift and alter the perceived timing of events on the star's surface.
Participants express a variety of viewpoints, with some agreeing on the mechanics of visual phenomena and others contesting the interpretations of FTL motion. The discussion remains unresolved, with multiple competing views on the implications of the proposed experiments and thought experiments.
Some claims rely on specific assumptions about the nature of light and observation, and there are unresolved mathematical considerations regarding the scenarios presented. The discussion also highlights the distinction between perceived motion and actual physical movement.
Gonzolo
Hi, I've been thinking about too quite simple ways to create what I believe to be faster-than-light speeds, and would like to know your opinion.
First experiment:
1. Shoot a laser pointer on the moon on a clear night sky.
2. Move the dot through the diameter of the moon.
If a person standing on the moon could see the "red dot" (assuming no divergence). Couldn't he "see" it go faster than c if you flicked your wrist quickly enough?
Second experiment:
1. Take two sheets of paper, one in each hand and hold them out in front of you, facing you, so that they overlap. Tilt one of them slightly.
2. Now slowly separate them.
3. When the inside edges meet, you see an angle formed between the sheets. The vertex moves perpendicularly to the movement of the sheets.
4. The smaller the angle, the faster the vertex will move.
5. Since you can choose the angle to be zero, you can make the vertex go an infinite speed.
No mass or energy is involved, so no law is broken, but its a awfully simple way to have something (a vertex) go really fast.
Science news on Phys.org
First experiment:
About your first claim, in order to have the laser be seen moving faster than the speed of light, then you would have to flick your wrist at the speed of light. This is the maximum speed attainable in the universe, making the laser still travel at the speed of light to the observer.
About your second claim, there is not enough info, I am not sure what you mean.
I had the same kind of thought experiment. Look up my posts and see what the replies were. I think the post was called "speed of light broken?"
Actually, the 'dot' can move faster than the speed of light. However, the dot is most definitely not an object, but an intersection. A reasonably good occilloscope will have settings that allow a 'dot' to move faster than light as well. Of course, the intensity of the laser would have to be obscene in order to show up at that range and so on. With a reasonably fast spinning mirror, you should be able to get this type of effect on a more reasonable scale. Let's say you have a mirror spinning at 60,000 rpm and the dot is one kilometer away, you'll get a dot traveling at faster than light.
Similarly, the vertex is an intersection, and not actually a moving object. The classic example of this is, by the way, not two sheets of paper, but a large pair of scissors.
There's also the classic situation where an observer sees two things moving with apparent speeds of .75c in opposite directions which is also not a violation of SR.
Why not go outside, look to the horizon at your west, pick out a Star that is many Light Years away, now turn to the east sky horizon and pick out a Star at a similar distance. The total distance between both Stars would be easy to workout, equating to several Light years distance.
Now using a laser pointer directed at the West Star, arc your arm with laser, fast across the night sky till your laser points at the Star in the east.
If you were to physically travel from Star to Star it would take many Light yrs, yet you have virtually located the two Stars faster than light could in real terms.
The problem is that although you point your laser at a Star, say 10 light years away, you have not waited 10 light yrs for the light to actually arrive there before arcing your arm across the light sky!
Imagine if the Hubble Space Telescope swivelled its direction in a similar fashion, what sort of data would it retrieve?
Scissors are cool, but I have paper on my desk right now, and I can actually provoke an infinitely large speed using a zero angle as much as I want right now! It's so simple to go so fast, it keeps amazing me.
I thought of this, but the background on which the "dot" travels isn't as well defined. It can't really be observed. I think the moon is a nicer surface to illustrate the concept.
Thanks for confirming. The scissors and 60 000 rpm mirror are cool.
We use a 30,000rpm electric motor with a tiny mirror on top to measure the speed of light in the lab. A thin beam of light travels through a glass plate (at 45 deg) then onto the mirror. It then travels 3m to another mirror and 3m back again before hitting the rotating mirror and then going back through the glass plate. In the time the beam travels 6m, the mirror has moved a tiny bit (a very tiny bit!) and by measuring the distance the beam 'moves' on the glass plate you can work out the speed of light. The motor runs both ways to give an effective speed of 60,000rpm.
It works really well.
(...sorry if this is totally irrelevant!) :smile:
Not irrelevant, thanks!
There should be a situation in space where the illusion of FTL can happen. Say a star is moving toward the Earth at an angle of a few degrees. Observations of the star would show its sidways motion to be faster than actual because light from a previous observation traveled further to reach the earth. I haven't worked the math, but there should be some speed - angle for the star that make it appear to be moving faster than light.
Am I wrong or is it possible?
Vern
Vern
This wouldn't work out. Instead the doppler effect would blue-shift the image and time would appear to take place faster on the surface of the star from our vantage point.
Are you sure about that?
For example:
Code:
       A'   A
Imagine the observer 0, watching 'star A' moving across the sky. where A is it's inital postion and A' is it's final postion.
Lets say that the star travels from A to A' which will be a distance of x in a straight line and with constant velcoity v. for simplicite's sake let's say that the intial sepration is sqrt(2x^2) and the final sepration is therefore x.
The time taken for the star to move from A to A' is simply [itex]\frac{x}{v}[/itex]
Howvere the time taken for the image o travel from A to A' will be:
[tex]\frac{2x - \sqrt{2x^2}}{v}[/tex]
note:
[tex]\frac{x}{v} > \frac{(2-\sqrt{2})x}{v}[/tex]
So the apparent velcoity of the image will be:
[tex]\frac{v}{2 - \sqrt{2}}[/tex]
which may be bigger than c.
First experiment:
Second experiment:
Thoughts to offer:
First experiment... a) a pencil thickness laser beam shot from Earth at the moon would reach the moon spread by at least 1-football field(uncertain about the exact spreading) so in any event a "dot" is not possible.
b) moving the laser pointer on Earth to cross the diameter of the moon in a split-second is easy enough, but, the laser light does not cross the surface of the moon in the same way. Tkae a garden hose and direct a fine stream of water at a specific point in your yard. Now, move your hand quickly to another point and look at the stream. It arcs, and is delayed. The same thing happens with light under those circumstances. No FTL.
Second experiment... a vertex moving FTL. That has always interested me, as I have in the past considered how the vertex would move with two intersecting laser beams 10-feet apart, and then the 2 laser beams move left and right, respectively, causing the vertex to rapidly advance. Although the laser beam will arc, as described above, would the vertex move FTL? Don't know.
Hmmm... this begs a question: Has any authoritative studies been conducted with regards to FTL vertex movement? My suspicion is that it maxes at C, regardless of what one does.
That is, I see vertex movement to potentialize instantaneous expression, yet with the limits of propagation at C. Any thoughts?
I can't undertstand what you're saying. So let's simplify things a bit:
Let's say I have two inclined jaws, the top jaw has a very slight up slope, and the bottom jaw has a very slight downslope, Let's say the slope is .001 m per thousand meters. So, If I lower the top beam .001 m I get a vertext traveling 1000m - that's a factor of 1,000,000. So, if I get the jaws moving 300 m/s relative to each other, the vertex is moving at faster than light.
The vertex is not a massive object, so it can go FTL. (Phase velocities are commonly FTL.) But if you tried to put a pebble at the vertex and push it along, you will hit a ceiling.
The point on the moon will not travel FTL. How does flicking your wrist ensure that the dot moves correspondingly? The light will have to catch up, so the dot will lag behind the flick. In other words, the dot will reach the final position only after time, t=d/c subsequent to the flick reaches its final position.
Are you getting paid to do this? :smile: (Reminds me of the Dilbert cartoon where they're flicking their fingers.)
The dot moving across the moon faster than the speed of light is an illusion. The light is traveling from Earth at the speed of the light. Each photon is landing a little to left (or right) of the one before. It doesn't matter how much sooner or later the photon arrives, the speed of light is constant. So, if one were able to measure the time between the first dot appeared at one side of the Moon and the time the last dot appeared at the other side, the dot would appear to have moved faster than the speed of light. (Of course, the intensity would have been reduced in response to the spreading of the light beam due to you flicking your wrist [added on to the normal spreading of a light beam])
Rather than trying to move a vertex really fast, just transmit a radio signal into a wave guide at an angle. If you were to measure the waves along the side of the wave guide, they would appear to be alternating between faster than light and slower than light. Once again, it's an illusion based on the point of view.
In fact, Palladin's comment about the dot spreading to the size of a football field is a perfect analogy. How much time elapsed between the light arriving at one side of the football field size dot and the other side. They're not the same photons arriving at either side - they're two different photons that happen to arrive at the same time.
I totally agree. I am convinced because it is allowed to separate the edges with angle zero. A guillotine comes to mind. Choosing an angle 0 + d[tex]\theta[/tex] creates a vertex that can go any speed imaginable, such that [tex]lim_{\theta->0}v = \infty[/tex]. It's important to note that no information can be transmitted this way, since it must "come from the middle" , or both ends simultaneously. Pushing on one end of the blade implies information must travel to the other end through phonons, which are slower than light.
I do not find this obvious. The dot may not move correspondingly, but I wonder if the "arrival of the next dot" (think of a machine gun) cannot move FTL. Imagine drawing a line with a water hose on the pavement... oh I think I get it... right. It comes back to the guillotine pushed on one end. I agree with you.
Well first, I did assume no divergence. Second, even if there was, my argument would have been about the center of each football field instead of the dots. Third, I think Gokul is right, it doesn't work. Fourth, I think two photons arriving at the same time is pretty much the same as the vertex effect, in which, ends of an edge replace photons.
About the scissor and overlapping paper thing:
You said they had to be long scissors and I've heard this before but was never sure why. About a year ago I set out on finding why, did some calculations and determined that they had to be long scissors, or you just have to close regular length scissors really fast. This is because the blades don't become parallel until after the intersecting point has gone past the blade, therefore it doesn't achieve infinite velocity.? I think I found that the end velocity on typical sized scissors cutting at a typical rate, the end velocity of the intersection point wasn't really close to c. Anyway, is that how it works? I tossed out my notes about it a while ago, but just wondering if that sounds right.
I think that for actual scissors, the vertex will never pass c. It is true that the longer they are, the "more parallel" they are at their end, as the faster the vertex will go. However, true scissors are made of atoms, and the interaction time between atoms is less than c. When you close them, their end lags the rest, they do not stay perfectly straight. For true FTL, overlaping edges such as in a guillotine work best (in which all atoms are pulled by a field simultaneously).
The thing is that there isn't anything actually moving at any speed close to c. It's a 'point' of intersection, but there isn't anything physical there, therefore, the point could theoretically move at any velocity.
I'm not sure about the dot on the moon since I can't be bothered to plug and chug right now, but I'm quite certain that the occiloscope traces actually do get faster than the speed of light.
*Here's my first attempt with LATEX
I'm too lazy to differentiate this or set restrictions on the independent variable now, but here’s the math for the scissor thing:
Let T represent the distance from the pivot of the blades to the perpendicular intersect of a blade.
Let R represent the distance from the pivot point of the blades to the point of intersection of the blades.
Let L represent the length from the pivot point of the blades to the tip of a blade.
So:
Rminimum = [tex]\sqrt{2 \cdot T^2}[/tex]
Rmaximum = [tex]\sqrt{L^2 + T^2}[/tex]
Let [tex]\Theta[/tex] represent the angle of the intersection of the blades.
Therefore:
[tex]R(\Theta) = \frac{T}{\sin \frac {1}{2} \Theta}[/tex]
Where [tex]\sqrt {2 \cdot T^2} \leq R(\Theta) \leq \sqrt {L^2 + T^2}[/tex]
This formula should be enough to start with for anyone who wants to find the velocity of the intersection point, dependent on the rotational speed of the blades. I just don't feel like going through all that, again... but if u graph this, with the restrictions you'll be able to determine the final velocity at the tip is not moving at c, unless your scissors are long or unless you're closing the scissors really fast.
Would you believe you could get at least the speed of light?
How fast do the electrons move on their way from your car battery to your starter? Do you really think electrons, particles posessing mass, move the speed of light down your battery cable? An electronics instructor once told me it takes about three days for an electron to make it from my battery to my starter. Yes, I did have a pretty lousy car, but that's totally irrelevant.
The speed of electricity was still at the speed of light, in spite of the fact that the electrons moved very slowly. While each electron barely moved, there are oodles* of electrons in a copper wire and a whole string of these electrons move in rapid succession (in fact, their rapid succession occurs at the speed of light).
The 'effect' can be much faster than the movement of each individual member. If each member (each photon) is already moving at the speed of light, it should be no great feat to provide a 'faster-than-light' illusion (i.e. an effect that occurs faster than light).
*You should be able to convert this to a more standard unit of measure using any good conversion table.
I actually heard that they move about a foot/sec or something like that.
I thought that the idea of special relativity made sure that there existed no "completely rigid" materials. That means that even if you flicked the "infinitely big scissors", the action would still be transmitted at most at the speed of light.
I wouldn't expect the vertex on real scissors to go c. I'm not even sure for long or fast scissors, since ultimately, there's a lag along the length due to the fact that no material if perfectly rigid (phonons don't go faster than c). But it's a nice example of a vertex. I now think the only way to get a vertex go >c would be by having one of the edges brought towards the other with a field, pulling the entire thing simultaneously. A small angle is of course necessary too.
Bobg, I think the effect you would be talking about is phase velocity, which can go faster than light, either with e currents or light waves. It's been done for both.
For example:
Code:
       A'   A
note:
Nevermind. I suppose you were right. In fact, if something traveled directly toward you at the speed of light it would appear to have traveled at an infinite speed, since its image would travel along with it. This is impossible of course, but it demonstrates the fact that something appears to be moving faster when it moves toward you. In fact, this is actually what causes blueshift as well as time compression (time on the star's surface will appear to be ticking away faster than here).
A little correction, however. The time between the first image and last image would be:
t= x/v + x/c - sqrt(2x^2) / c
which in the best case scenario of v = c would be:
t= 2x - sqrt(2x^2) / c
in which case the image would move faster than the speed of light
The speed of an electron moving in a copper wire does not reach the speed of light, nor does the "rapid succession" of electrons.
OK, but if that is true, than I can transmit data FTL through vertex manipulation, so I question it's reality. Allow me to explain:
Using the 2 inclinded jaws as you described, the angle of separation(in this case) will cause a non-mass vertex movement to go FTL. Correct?
I can easily create sensors that determine whether or not a vertex exists at any given point. Agreed?
So, if I put a sensor at the beginning of the jaws to indicate vertex starting, and one at the end to indicate vertex arrival, the second sensor should "trigger" a vetex moment faster than C. Right?
With that I manipulate the jaws in Morse Code to transmit data FTL.
  • · Replies 18 ·
