Maximum altitude of a rocket in 2D motion and free body motion
The maximum altitude of a rocket launched at a 53-degree angle with an initial speed of 75 m/s and an acceleration of 25 m/s² is calculated to be 7750 meters. The calculations involve using the displacement equation, where vertical displacement is determined through vector analysis and trigonometric functions. After engine failure, the rocket continues its ascent until reaching its peak altitude, where its velocity becomes zero. The initial vertical velocity was miscalculated as 60 m/s instead of accounting for the acceleration, which significantly impacts the final results.
  • Understanding of kinematic equations in physics
  • Knowledge of vector components and trigonometry
  • Familiarity with free body motion concepts
  • Ability to analyze projectile motion
  • Study kinematic equations for projectile motion in detail
  • Learn about vector decomposition and its applications in physics
  • Explore free body diagrams and their role in analyzing forces
  • Investigate the effects of varying angles and initial speeds on projectile trajectories
Students studying physics, particularly those focusing on mechanics, as well as educators looking for examples of projectile motion and free body analysis.
optoracko
A rocket is launched at an angle of 53 above the horizontal with an initial speed of 75 m/s. It moves for 25s along it's initial line of motion with an overall acceleration of 25 m/22. At this time its engines fail and the rocket proceeds to move as a freebody.
a) What is the rocket's maximum altitude?
displacement = V1time + (1/2)a(time)2
V2 = V1 + 2adisplacement
I've googled this question after attempting it, and have seen several different methods from my own.
For part a, I'm interpreting it as the maximum vertical displacement. I set up a vector diagram, where the angle between the average velocity vector and horizontal velocity vector is 53. I use sin ratio to solve for the opposite, which is sinTHETA x hyp. This gives me 60m/s. I do the same process to find the vertical acceleration, which is 20.0 m/s2. I plug them into the displacement equation, solve to get 7750m.
Now for the free body motion. Velocity will equal 0 when it gets to it's top. I use the second equation to rearrange for displacement. V2 is 0, V1 is -602, acceleration is -9.81. Essentially, displacement is a negative value. Meaning the max. altitude is still 7750m.
Makes sense to me, but I applied the same approach to a different question (identical) with diff. values. The answer was way off. (I did this to see if my approach was right).
What am I doing wrong?
What will be the rocket's velocity when it runs out of fuel?
V1 is -602
V1 isn't 60m/s because the rocket has been accelerating.
  • · Replies 47 ·
  • · Replies 38 ·
