Impulse: Clay ball that sticks vs. Rubber ball that bounces?
The discussion revolves around a problem in impulse, comparing the effects of a rubber ball that bounces off a wall and a clay ball that sticks to it. Both balls have the same mass and are thrown at the wall with equal speeds.
  • Participants explore the concept of impulse using different expressions, questioning the relationship between change in velocity and impulse for both types of balls. There is a focus on the implications of direction change for the rubber ball compared to the clay ball.
Some participants have offered insights into the calculations of impulse based on changes in velocity, while others are affirming the reasoning presented. Multiple interpretations of the impulse exerted by each ball are being explored.
Participants are considering the definitions and implications of impulse without specific numerical values or detailed force-time relationships, which are not provided in the problem statement.
Glorzifen
A 10 g rubber ball and a 10 g clay ball are thrown at a
wall with equal speeds. The rubber ball bounces, the
clay ball sticks. Which ball exerts a larger impulse on
the wall?
J (impulse) = Favg*dt
I think that the rubber ball would exert more of an impulse because it's dt would be larger. Since it has to hit the ball and bounce of it, as opposed to the clay, which hits the wall and stops.
Thoughts?
Impulse is either F*Δt or m*Δv.
The first expression is difficult to use because you don't actually know the force and duration of the collisions with the wall. Use the second expression. The difference is in the Δv.
Thought I replied to this.
Okay, so with the clay ball, the change in v is from x to 0, so it's -x. The rubber ball bounces though...and though it may leave the wall with a different speed, it's velocity has changed more than the clay ball's since it changed direction (x to -x...so -2x roughly). Therefore the rubber ball is exerts more impulse on the wall?
right.
15K
  • · Replies 19 ·
9K
  • · Replies 24 ·
