Where does my (small) notebook go wrong?
  • Thread starter Thread starter Shukie
The discussion focuses on using NonLinearModelFit in Mathematica to determine Rydberg's constant from a dataset obtained via a spectroscope. The user encountered issues with the model not functioning correctly due to inadequate starting points for the parameter "p". It was concluded that starting points such as {p, 0} or {p, 0.027} yield successful results, allowing the model to fit the data appropriately.
  • Familiarity with Mathematica's NonLinearModelFit function
  • Understanding of Rydberg's constant and its significance in spectroscopy
  • Basic knowledge of nonlinear fitting techniques
  • Experience with dataset preparation and manipulation in Mathematica
  • Research advanced techniques for parameter estimation in NonLinearModelFit
  • Explore the impact of different starting points on model fitting accuracy
  • Learn about data weighting in Mathematica to improve fit quality
  • Investigate other fitting functions available in Mathematica for spectroscopy analysis
Researchers, physicists, and data analysts working with spectroscopy data and those looking to enhance their skills in nonlinear modeling using Mathematica.
Shukie
Hi all,
A few days ago I have done an experiment with a spectroscope to find the value of Rydberg's constant. In my notebook I have a dataset that I want to use a NonLinearModelFit on to find this constant. However, it will not work and I just can't figure out why it won't. I have gotten rid of everything else in the notebook to keep it as clear as possible:
View attachment Notebook1.nb
Could anyone please take a look?
I think the problem is all in your starting points. Do you have a better starting point for "p" than one?
I see that {p,0} or {p,0.027} works:
Code:
fit3 = NonlinearModelFit[
  dat1, \[Theta]nul + \[Alpha] + (ArcSin[p k - Sin[\[Alpha]]]), {{p,
    0}, {\[Theta]nul, 3.15}, {\[Alpha], 0.}}, k, Weights -> wt]
Thanks a bunch, that works indeed!
  • · Replies 24 ·
