Thread Closed
The influence of crossing angle on amplitude in cable to cable coupling
Share Thread Thread Tools
Mar2-10, 08:20 AM   #1
Hi all,
I have this project i have to write but i am having trouble getting the necessary materials to aid my writing. The project topic is the influence of crossing angle on amplitude in cable to cable coupling. It is a magnetic coupling problem and i am supposed to design a workbench to demonstrate it.
2. Relevant equations
I need to interpret data from the experiment.
3. The attempt at a solution
I tried to analyze it in this manner: An experimental set up to demonstrates the influence of magnetic field coupling from an power cable to a nearby signal cable.The experimental set would demonstrate the impact of parallel cable layout as well as when the cables cross.
What happens when a power/signal cable is placed in close proximity to the cable not carrying current or carrying a signal of a different frequency?
Please find attached pictures of a workbench with the cables placed in parallel.
Thanks, i would appreciate any help.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Mar2-10, 11:32 AM   #2
Mentor
Quote by jadedchi08 View Post
Hi all,
Welcome to the PF. Your pictures show coaxial cables -- are you trying to model crosstalk between coaxial cables? That coupling should be quite low, and is generally not an issue that I am aware of.
You mention a power cable and a signal cable in the text of your post -- that is quite different from the pictures. What are the constructions of the power and data cables?
Apr19-10, 10:00 AM   #3
I was able to model something. I used two coaxial cables, one of the cables i connected to a signal generator, the other i connected to an oscilloscope, and crossed both cables. The cable connected to the scope i moved, varying the angles between both cables.
I saw some induced voltage but the voltage did vary even after varying the angles between both cables. The whole idea of the project is to get the readings of the induced voltage at different angles between both cables. I don't know if i should blame it on the scope because it is quite old.
I would really appreciate any help i can get and any articles/journals/papers highlighting induced voltage and how to calculate it.
Thanks.
Apr19-10, 04:31 PM   #4
Mentor
Thanks.
Are you terminating the coax cables in their characteristic impedances? Honestly, cross-talk between coax cables that are handled properly (even when run together) will be minute.
The search terms you should use are Near End Crosstalk (NEXT) and Far End Crosstalk (FEXT):
http://www.answers.com/topic/unger-model
You can find some experimental help by using those search terms.
Thread Closed
Thread Tools
Similar Threads for: The influence of crossing angle on amplitude in cable to cable coupling
Thread Forum Replies
critical angle inside cable Introductory Physics Homework 1
Cable theory - calculating cable length using graphs Advanced Physics Homework 2
cable tension at an angle Introductory Physics Homework 2
Tension in a cable at an angle Introductory Physics Homework 1
Tension in a cable car's cable Introductory Physics Homework 2
