Finding Chen's Paper: "On the Representation of a Large Even Integer
The discussion revolves around locating a copy of Chen's paper titled "On the representation of a large even integer as the sum of a prime and the product of at most two primes." Participants are exploring avenues to access this paper, including library resources and alternative literature.
  • Meta-discussion
  • One participant expresses difficulty in finding the paper and mentions that they can only find references to it, not the actual document.
  • Another participant suggests that the paper is in Scientia Sinica Series A and implies that older volumes may not be available electronically.
  • A third participant notes that their library only has access to Series G, indicating a limitation in available resources.
  • One participant points out that while not the original paper, a proof of Chen's theorem can be found in Melvyn Nathanson's book "Additive Number Theory, The Classical Bases."
  • Another participant recommends Nathanson's book as a good read, regardless of the desire to access the original paper.
Participants generally agree on the difficulty of accessing the original paper and suggest alternative resources, but there is no consensus on the availability of the paper itself.
Participants mention limitations in library access and the potential unavailability of older journal volumes electronically.
FunkyDwarf
Hi guys,
Not actually a mathematics question as such (sorry) but does anyone know where i can get my hands on a copy of Chen's paper "On the representation of a large even integer as the sum of a prime and the product of at most two primes". For the life of me all i can find is references to it rather than an actual pdf copy, or even any information about the journal it is from (Sci. Sinica 16 (1973) 157-176) ie reference given below.
http://en.wikipedia.org/wiki/Goldbach's_conjecture#cite_note-13
I have access to science direct and springer link but none seem to have it :( Any ideas?
Cheers
-G
EDIT: Ok so i found that its in Scientia Sinica Series A which springerlink has going back to 1997, I'm assuming if they don't have volumes further back they're not available electronically?
Right. You'd need to find a (university) library that had it.
Bugger, mine only has Series G. Righto, time to get on the wire and bug my 'colleagues' :)
Cheers!
Although not the original paper, the proof of Chen's theorem may be found in Melvyn Nathanson's book "Additive Number Theory, The Classical Bases", Springer, 1996, p. 271 ff., ISBN 0-387-94656-X.
Actually, that's a good book to read even if you do want to read the original...
12K
  • · Replies 39 ·
  • · Replies 20 ·
