How far does a putty block compress a spring after an inelastic collision?
The problem involves a block attached to a spring on a frictionless surface, where a wad of putty collides with the block inelastically. The goal is to determine how far the combined system compresses the spring after the collision.
  • Participants discuss calculating the velocity of the block-puddy system post-collision and relate it to the spring constant. There is exploration of the conservation of energy principles in the context of the spring's potential energy and the kinetic energy of the system.
Some participants have made progress in calculating the velocity and kinetic energy of the system. Guidance has been provided regarding the conservation of energy, and there is an acknowledgment of the relationship between kinetic energy and spring potential energy. However, the discussion remains open with various interpretations being explored.
Participants are working under the constraints of a homework problem, which may limit the information available for discussion. Assumptions regarding the conservation of energy in the absence of friction are being examined.
jwang023
A 0.440 kg block is attached to a horizontal spring that is at its equilibrium length, and whose force constant is 23.0 N/m. The block rests on a frictionless surface. A 5.90*10^-2 wad of puddy is thrown at the block, hitting it with a speed of 2.50 m/s and sticking. How far does the putty block system compress the spring?
I wrote down the equation for springs. U= 0.5kx^2
I have drawn a picture and figured out the momentum of the puddy onto the block, but not sure what to do after that.
Calculate the velocity of the block-puddy system.
ehild
I have found the velocity of the puddy block. Trouble is, I'm having a hard time relating it back to the spring constant.
After collision, the forces are conservative, as the friction does not count. The block and puddy together have some kinetic energy. They push the spring and the spring exerts force on them, and the total energy of the moving mass + spring is conserved. On what depends the energy of the spring?
ehild
Ok I get it. I went and found the Kinetic energy of the block/puddy after I found the final velocity of the two. Since you said that they were conserved I set the K=Uspring. and solved for x after converting meters to centimeters. Thanks for the help! :)
  • · Replies 21 ·
