Is a High Horsepower, Lightweight Diesel Engine Possible for a Race Truck?
The discussion revolves around the feasibility of building a lightweight race truck powered by a high horsepower diesel engine. Participants explore various aspects including engine specifications, power-to-weight ratios, and the implications of different engine types and configurations for racing applications.
  • Experimental/applied
  • One participant seeks recommendations for a high horsepower diesel engine that is lightweight enough for a race truck project.
  • Another participant questions the desired power-to-weight ratio and the specific type of racing, suggesting that there are many high-performance diesel engines available.
  • A participant mentions a performance diesel/hybrid sports car featuring a micro-turbine engine, expressing uncertainty about its implications for the project.
  • Concerns are raised about the weight of diesel engines due to high compression ratios, with suggestions to look for engines with lower compression ratios.
  • Discussion includes the potential of turbine engines for better power-to-weight ratios, although practicality for a race truck is questioned.
  • One participant asserts that modern diesel engines maintain high compression ratios, countering earlier claims about decreasing ratios, and discusses advancements in materials and turbocharging.
  • Another participant suggests specific diesel engines, such as the V6 and V10 TDI from VW, noting their power output and potential for the project.
  • A participant outlines their project goals, including a target horsepower range and budget constraints, while expressing a preference for diesel engines out of curiosity.
  • Concerns about durability and the appropriate engine size for achieving the desired horsepower and torque are raised.
Participants express differing views on the compression ratios of modern diesel engines, the practicality of turbine engines, and the specific requirements for the race truck project. No consensus is reached on the best approach or engine choice.
Participants mention various assumptions about engine specifications, performance characteristics, and project goals, which may not be universally applicable. The discussion reflects a range of experiences and knowledge levels regarding diesel engine technology and racing applications.
Individuals interested in automotive engineering, diesel engine performance, race truck design, and those exploring high-performance engine options for racing applications may find this discussion relevant.
Frostfire
Hey, I am working on a project and yahoo answers hasn't been much help. I am building a light weight race truck and I was hoping someone in here had heard of a high horse power diesel engine that wasn't heavier then the rest of the truck :)
What sort of power/weight ratio are you looking for? There are loads of very high performance Diesel engines around these days. Small truck? Big truck? What sort of power are you after? What sort of racing?
Coincidentally, I got an e-mail from a friend today about this performance diesel/hybrid sports car with impressive performance numbers:
http://reviews.cnet.com/8301-31166_7-10406217-271.html
They say something about the diesel engine bing a micro-turbine, but I don't know what that means. Might be worth checking out...
From what I gather, diesel engines are heavy for their power output (ignoring the fact that they don't rev very hard) is due to their high compression ratio. The latest diesel engines in cars are dropping their compression ratios and becoming more like petrol engines so a mechanic friend was telling me. So I'd say look for the engines with lower compression ratios.
Additionally, the Abrahams tanks that can do something like 50km/h run on a turbine engine that uses diesel as a fuel. Turbine engines generally have a better power to weight ratio as far as I know.
Otherwise check out the details of the Audi R10 Prototype GT car and the Peugeot equivalent. Both ought to have high power to weight ratios as they are being raced (and doing well) in the LeMans 24hr and GT races. They run on diesel that has been made from gas though (gas -> diesel as they do in South Africa), so I'm not sure how much that has an influence on their performance.
Thanks for the links and info, that gives me a direction to go in. Its a normal truck like a prerunner just a really light wieght one relitively. Vale-46 I agree with the sentiment but I need higher compression to deal with some serious turbo charging, anyone have any ideas what the newer diesels are running at compression wise?
Why do you need higher compression ratio for heavy turbocharging? A lower compression ratio will allow higher BMEPs with high pressure ratio turbocharging better than a higher compression ratio, since you'll be limited on peak cylinder pressures (or possibly exhaust temperatures).
I ask again, what sort of power are you looking for? What is your intended application (or duty cycle, are you entering drag racing events, or 24 hour rallies?). What's a "normal truck"? Are you concerned about anything else, like fuel consumption, reliability, durability, smoke, cost, heat rejection?
If we can understand what you're trying to do, you'll get some great advice here (I develop turbocharged Diesel engines for a living, and there are plenty of others here with engine and racing experience).
This isn't true. Compression ratios in modern diesel engines are just as high as ever since there is a minimum CR required for compression ignition. Modern diesel engines are lighter in some cases because the engine block is made out of higher strength materials, and turbocharging is more prevalent allowing smaller displacements for a given power output.
Turbine engines definitely have significantly higher power to weight ratios than piston engines, but it's obviously not realistic to tell this guy to put a diesel turbine in his truck.
The Audi Racing TDI engine is a very impressive engine, but where is the OP going to get one? One engine he might look into is the V6 TDI or V10 TDI out of a wrecked VW Touareg, although it might be difficult to find a transmission to mount up to it. The V-10 TDI puts out 309 HP and 553-627 ft-lb of torque depending on production year, pretty healthy for 4.9l of displacement. That's probably the best power to weight ratio from a diesel engine you will be able to find in a production car.
Hey thanks for all the advice, I am building it for a desert race and sand dune travel. I want to keep the build below 40K for parts. I am looking at between 600hp and 1400hp and below 2000flbs for the driveline I have set up. I was interested in diesel engine mostly out of curiosity as apposed to an ls7 or simaliar. Ultimatly I am interested in a gaseous state fuel but that's down the line. I am an engineering student and was looking to improve a project I have had around for a while. I want it to last for as long as possible, be as cheap to operate as possible but I am not incredible worried about initial cost.
thanks again
For durability, for something like that I'd probably be looking at something like a 11-13 litre truck engine, and very carefully revisit the turbocharging. But I don't know whether your definition of 'truck' is the same as mine.
The amount of horsepower you're looking for is a lot... what size engine are you hoping to get that out of? What size truck? How heavy? Do you really have a driveline that will put up with 2000 ft-lbs of torque?
  • · Replies 18 ·
  • · Replies 120 ·
26K
  • · Replies 39 ·
