Mass spec voltage and magnetic field
This discussion revolves around a mass spectrometer problem involving the calibration of the device using protons and helium ions. The participants are exploring the relationship between voltage, magnetic fields, and particle trajectories in the context of mass spectrometry.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the equations governing the motion of charged particles in electric and magnetic fields, questioning which equations are most appropriate for different scenarios. There is also consideration of how to account for the Earth's magnetic field and its potential impact on measurements.
Some participants have offered equations and insights into the relationships between voltage, charge, and magnetic fields. There is ongoing exploration of how to calculate the necessary voltage for different ions and how to assess the error introduced by external magnetic fields. Multiple interpretations of the problem are being considered, particularly regarding the contributions of the Earth's magnetic field.
Participants are working under the constraints of a fixed geometry for the mass spectrometer and are attempting to derive values based on given parameters. There is mention of confusion regarding the setup and the need for visual aids to better understand the configuration of the slits.
sweetdion
These question deal with a mass spectrometer whose slits are separated by .1 m.
a) Trying to calibrate it using protons, for B=.2T, the proton starting at rest should be accelerated through a voltage of _________ to have it pass through the two slits.
b) To set it with He2+ ions, with 2 protons and 2 neutrons, so that they pass through both slits, they need a voltage of _________. (Take into account a fixed geometry where r and B are constant.
c) Assuming that the Earth's magnetic field ifs 0.5x10^-4 and is perpendicular to path of particles, how much error is possible using the He2+ particles?
1/2mv^2=qV
F = qvB
qE = qvB -->
a) should i use the 3rd equation for this one?
b) same equation but change value for q to 2q?
c) I have no idea on this one
Please help, I'm so lost in this problem.
Can you show a picture? I can not imagine those slits.
ehild
ehild
this is the best i could do. The line should be curvy but i did it by freehand and the B circles should have dots in the center of them
been working on this a bit more. Some new equations have caught my eye.
v=E/B, mv^2=qV so v=squareroot(2qV/m)
R=mv/qB
F=-qvBkhat
q/m=E^2/2VB^2
I think the last equation is the best one, but I don't know how to find the electric field.
So the trajectory of the particle must be a half-circle between the two slits. OK.
To calculate the speed of the particle you need the voltage V between the electrodes it traverses (you denoted it by delta V but it is difficult to write that delta). As you know, the electric field does qV work, that work increases the kinetic energy so
1/2 mv2= qV (eq. 1)
You have written this equation in your first post.
You know that the Lorentz force on a particle in a magnetic field is
FL=qvB
when the v velocity of the particle is perpendicular to the field lines.
This force drives the particle around a circle of radius R, so the Lorentz force is equal to the centripetal force. The centripetal force is
Fcp=mv2/R.
FL=Fcp ----> mv2/R=qvB,
solving for v, it is
v=qBR/m (eq. 2).
The particle makes a half circle, so the distance between the slits is the diameter of the circle, how long is then R?
Now, about the calibration. The particle is proton. What are the mass and charge of the proton? You find them anywhere.
You know R, m, q, B, calculate the speed of the proton, then use eq. 1 to get the voltage between the electrodes.
Now do the same with the alpha particle.
ehild
okay but with the alpha particle, to calculate the velocity do i just add up the charges and the masses? when I add up the charges...they cancel, and I get 0. I don't think the velocity can be 0.
nevermind...i consulted wikipedia and found the answer to that question. thanks for your help! Now to find the error using the alpha particles. I plug in the new B and see what I get? Or should I add B of Earth and 0.2T. Then compare what I get from using this B with the first B? But the Earth's electric field is perpendicular, how does that enter into the equation...
Add the contribution of Earth to the original B and see the difference you get in the voltage. Then do the same with subtracting the field of Earth, as you do not know, if the magnetic fields point in the same or opposite directions. Take the deviation of the voltages from the original voltage and choose the magnitude of the bigger one as the uncertainty. Or maybe, you need to give it in percent of the original voltage.
ehild
thanks so much on this problem ehild.:-)
edit: nvm this post
  • · Replies 18 ·
