Irregular Cone Geometry Problem: Finding the Area of an Elliptical Base
  • Thread starter Thread starter Appity
    Cone Geometry
The discussion focuses on calculating the area of the base of an elliptical, non-right cone using two parameters: the length from the center of the ellipse to the vertex and the angle of the cone's sides. The area can be determined using the formula A = πab, where 'a' and 'b' represent the semi-major and semi-minor axes of the ellipse. Participants suggest employing trigonometric methods to derive the lengths of these axes by creating a right triangle from the cone's vertex.
  • Understanding of elliptical geometry
  • Familiarity with trigonometric functions
  • Knowledge of cone properties
  • Ability to apply geometric formulas
  • Study the derivation of the area of an ellipse using A = πab
  • Learn about the properties of non-right cones
  • Explore trigonometric applications in geometry
  • Investigate methods for slicing cones to analyze cross-sections
Students studying geometry, mathematicians interested in conic sections, and educators seeking to explain elliptical cone properties.
Appity
I'm wondering whether or not it is possible to get the area of the base of an elliptical, non-right cone if the following two parameters are known:
- length from center of ellipse up to vertex
- angle that the sides make
Here is a simple visual: http://i.imgur.com/M6jT5.png
[tex]A=\pi ab[/tex]
I've tried looking at geometry guides with no success. I'm thinking I might be able to use some clever trig and drop a right angle down from the vertex in order to get the length of the semi-minor/major axis, but I can't reason it out. any advice would be appreciated.
Hi Appity! :smile:
Hint: slice the cone so that you get a circular cross-section, then use trig to find the area of the projection. :wink:
24K
