Complete, Equivalent, Closed sets
The discussion revolves around the properties of equivalent sets, specifically focusing on completeness and closedness. Participants explore whether these properties can be transferred between sets that are equivalent, as defined by cardinality and one-to-one correspondence.
  • Some participants question whether the completeness of set A implies completeness for set B when A and B are equivalent.
  • Others suggest that equivalence, defined by cardinality, does not guarantee that properties like closedness are preserved between sets.
  • A participant notes that while equivalent sets have the same cardinality, they may differ in closure properties, particularly in the context of open and closed intervals.
  • There is a proposal that if sets A and B are isometric, then the closedness of A might imply the closedness of B, although this is debated.
  • Another participant emphasizes that the only inherent measure of a set is its cardinality, which does not necessarily dictate closure properties.
  • A later reply introduces the concept of a metric preserving homeomorphism as a condition under which the properties may hold.
Participants express differing views on the relationship between equivalence and properties like completeness and closedness. There is no consensus on whether these properties can be transferred between equivalent sets.
Participants reference specific definitions of equivalence and cardinality, but there are unresolved assumptions regarding the implications of these definitions on set properties. The discussion also touches on the need for stricter conditions, such as isometry, to draw conclusions about closedness.
Somefantastik
If a set A and a set B are equivalent, and it is known that A is complete, can it then be said that B is also complete?
What if it is known that A is closed, can it then be said that B is also closed?
Two sets are equal if they have the same elements. So the set A=B={[0,1]} is closed because it contains both 0 and 1. I don't know if you mean something different by using the term "equivalent".
Kolmogorov states that equivalents sets are those on which a one-to-one correspondence can be found.
This means two sets have the same cardinality. Since both the open and closed sets on the real interval 0,1 have the same cardinality, A and B may nevertheless differ in terms of closure. If you wish to call the closed interval "complete" then the open interval would not be "complete".
Can you clarify that statement a little?
Also, would making the requirement more strict, maybe saying if the sets A and B are isometric, then A closed implies B is closed?
If a < b, then |[a, b]| = |(a, b)| = |(a, b]| = |[a, b)| where |...| is the cardinality.
What metric are you defining for your sets? The only inherent measure of a set is the number of elements it contains (ie its cardinality). The fact that sets A and B have the same cardinality doesn't imply that if A is closed, B must be closed.
Nevermind, I have the answer...it works when you have a metric preserving homeomorphism between the sets.
  • · Replies 18 ·
