Calculating Power Dissipation in a Parallel Circuit
The discussion focuses on calculating power dissipation in a parallel circuit involving a 10 ohm resistor dissipating 40W and a 5 ohm resistor. The power dissipated by the 5 ohm resistor is determined to be 45 watts using the formula P = I^2 * R. The current through the 5 ohm resistor, I1, is calculated to be 3 amps, while the current through the 10 ohm resistor, I2, is 2 amps. The analysis employs both the junction rule and loop rule to derive these values accurately.
  • Understanding of Ohm's Law
  • Knowledge of power formulas in electrical circuits
  • Familiarity with parallel circuit analysis
  • Ability to apply Kirchhoff's laws
  • Study the application of Kirchhoff's Junction Rule in complex circuits
  • Learn about power calculations in series and parallel circuits
  • Explore the implications of resistor values on current distribution
  • Investigate advanced circuit analysis techniques using simulation tools
Electrical engineers, physics students, and anyone involved in circuit design or analysis will benefit from this discussion, particularly those focusing on power dissipation in parallel circuits.
Linus Pauling
1. The 10 ohm resistor in the figure is dissipating 40W of power. How much power is the 5ohm resistor dissipating?
2. P = I2*R
3. I = sqrt(P/R) = 2. I then did P = I2R = (4)(5) = 20 which is incorrect.
well, I have exactly same problem and I solved only one case:
So, we have 10 ohm and 40 watt.
the Power = V^2/ Ohm then we can calculate the volt on 10 ohm.
The power on 20 ohm then, is // resistor with 10 ohm.
Then they should have same potential difference.
So you can find the power at 20 ohm...
BUt...
I am lost with 5 ohm too... anybody else?
The current through the 5 ohm resistor is not equal to the current through the 10 ohm resistor, because the current "splits" at the junction where the circuit becomes parallel. Let the current through the 5 ohm resistor be I1, through 10 ohm be I2 and through 20 ohm be I3. Let the junction A be where the circuit first branches off into the 2 parallel circuits. Then, by the junction rule, the current going into junction A must be equal to the sum of the currents out of junction A and into the two parallel resistors.
Junction @ A : I1 = I2 + I3
Since P = I^2 R, we need to find I1 in order to calculate the power dissipated by the 5 ohm resistor. We use the loop rule to find current I3, since we already know I2 = 2 amps. So draw Loop 1 clockwise around the inside of the parallel part of the circuit (containing the 10 ohm and 20 ohm resistors). The sum of the voltage drops (V=IR) across the circuit equals zero. We start at the junction A, and determine the voltage drop across each resistor around the loop.
Loop 1 @ A: -(20 ohm)(I3) + (10 ohm)(I2) = 0
The Loop 1 equation gives I3 = (1/2)I2. Substituting I3 into the junction A equation, with I2 = 2 amps, we get I1 = (3/2)I2 = 3 amps. So the power dissipated by the 5 ohm resistor is P = I^2 R = (3 amps)^2 * (5 ohms) = 45 watts. Feel free to make any corrections.
