Extraction Methods for Frozen Lunar Water Ice?
The discussion revolves around methods for extracting frozen water ice from shadowed lunar craters, focusing on the challenges posed by extremely low temperatures and the lunar vacuum. Participants explore various technological approaches and their feasibility for lunar colonization.
  • One participant suggests that developing a method to extract frozen water ice could be a valuable patent opportunity, emphasizing the importance of lunar water for future colonization.
  • Another participant raises a concern that using a hot knife to cut ice may lead to immediate re-freezing, complicating the extraction process.
  • Some participants propose that extracting adsorbed water from lunar regolith might be easier than retrieving ice from deep craters, questioning the efficiency of heating solids in a sealed chamber to avoid losing volatiles.
  • There is a suggestion to explore the use of electrical or magnetic fields to capture water vapor during extraction processes.
  • One participant mentions the potential to utilize the Moon's day-night cycles to facilitate harvesting water as temperatures fluctuate, possibly reducing energy expenditure.
Participants express multiple competing views on the best methods for extracting lunar water, with no consensus reached on a single approach or solution.
Participants highlight various assumptions regarding the physical properties of ice and water vapor in lunar conditions, as well as the limitations of current technology for extraction in a vacuum.
This discussion may be of interest to researchers in lunar exploration, engineers developing extraction technologies, and those involved in space resource utilization.
sanman
You want to think about technology you can patent? Come up with a way to extract frozen water ice in the shadowed craters on the Moon, which are at temperatures approaching absolute zero. He who controls the lunar water, controls the future of human colonization on the Moon.
Given that this frozen water could very well be the most precious commodity on the entire lunar surface, then people would pay an arm and a leg for a convenient way to extract and harvest it.
How do you grab ice that may be frozen at some ridiculously low temperature, in an area also at the same low temperature?
Microwave cutting? Simple hot knife?
How to grab any pieces you've chopped free?
What kind of apparatus would you use?
There's no way to suction anything in a hard vacuum. Is it better to pound on the ice and create ice chips, to then scoop them up like gravel? Would a jackhammer suffice?
What is the best way to grab this stuff and handle it, especially if you're doing it at the bottom of a deep cavity?
Should there be an X-Prize competition for this?
Haha. That could be interesting. Simply because if you hot-knife a block, it will almost instantly re-freeze... requiring you to somehow remove the melted water immediately.
On the other hand, maybe extracting the traces of adsorbed water from the regolith may be easier than going down into some deep shadowed crater to extract the ice.
But what I don't understand is how you evaporate volatiles in their vapor phase and avoid losing them to the hard lunar vacuum. To me, that requires heating your solids in a sealed chamber, which imposes a batch process over a continuous one.
Is there some way to use electrical or magnetic fields to corral the water vapor? Is there some regenerative catalytic process that could be used? What's the cheapest, most efficient way to do this to gather large amounts of water?
Oh, another thought - perhaps you could leverage the day-night cycles on the Moon, since the transition between night and day would see the water approaching its sublimation/frost point, so that you'd then be able to harvest more easily while expending less energy.
  • · Replies 21 ·
  • · Replies 152 ·
12K
9K
