Unraveling the Mystery of One-Half Coefficient in Kinematic Equations
  • Context: High School
  • Thread starter Thread starter Tanahagae
The discussion centers around the presence of the one-half coefficient in kinematic equations, particularly in the context of constant acceleration. Participants explore the mathematical and conceptual underpinnings of this coefficient, seeking to understand its derivation and implications in physics.
  • One participant expresses confusion about the one-half coefficient in kinematic equations and seeks a deeper understanding rather than memorization.
  • Another participant suggests that the coefficient arises from integration and differentiation, indicating a connection to calculus.
  • Some participants explain that the average speed is calculated as the mean of initial and final speeds, leading to the one-half factor when calculating distance.
  • One participant describes the area under a velocity-time graph as a triangle, which mathematically results in the one-half coefficient when calculating distance.
  • Another participant emphasizes that deriving the equations requires proving the average velocity equation rather than assuming it, suggesting a geometric approach using graphs.
  • There are discussions about the necessity of understanding the derivation process, with some participants feeling that many explanations skip crucial steps.
Participants generally agree on the mathematical processes involved in deriving the one-half coefficient, but there is no consensus on the best approach to explain or understand it. Some participants challenge the assumptions made in derivations, indicating ongoing debate.
Limitations include varying levels of familiarity with calculus among participants, which may affect their understanding of the derivations discussed. Some steps in the derivation process are noted as being skipped in common explanations.
This discussion may be useful for students new to physics and calculus, particularly those interested in the foundational concepts of kinematics and the mathematical reasoning behind physical equations.
Tanahagae
I have been in Physics for a month now and have been plagued by one simple detail, why in most Kinematic equations is acceleration given the coefficient of one-half? I have been researching lately and have not found any understand reasoning, in most explanations I just see the one-half appear as it had always been there.
Granted we do not have to understand how to derive one equation into another, I cannot have something like this on my conscience. I guess I like to understand rather than follow blindly. If anyone has explanation for the phenomenon I will greatly appreciate it. My math background goes as far as Calculus 1 which stopped at Integrals so hopefully these equations do not require anything beyond that.
Thank you. I love the forums, have been an abundance of help with any questions I come across in my efforts to do homework.
It comes from integration and differentiation. Are you familiar with basic calculus?
Some "Equations" conform to meet the "reality". Nature is not interested in conforming to "nice looking" equations.
@berkeman: Yes, I am familiar with basic Calculus. I know the majority of Physics deals with Calculus and honestly I am upset I am not allowed to take Physics 207 which is a Engineering physics course that revolves around Calculus.
@jmatejka: You are quite right, the equation is not "nice looking." I am more curious at why it is that way. I have a feeling my stay in Physics this semester will be much more enjoyable if I understand rather than memorize.
Well I probably didn't understand what you want but if I did, it comes from the fact that position = average speed * time, and average speed = (initial_speed + final_speed)/2. As final_speed is acceleration * time, after multiplying you get that a*t/2 in the formula...
Sorry if I said something stupid, anyway...
So start with a constant acceleration a.
To get velocity, you intetrate acceleration:
[tex]v(t) = v_0 + \int a dt = v_0 + at[/tex]
To get position, you integrate velocity:
[tex]y(t) = y_0 + \int (v_0 + at) dt = y_0 + v_0 t + \frac{1}{2} a t^2[/tex]
And in the case where a = -g (pointing down in the -y direction), you can see the equations that you normally use for projectile motion.
Does that help?
Yes, that was basically all I wanted to find out. I had no clue what the first step was, I knew how to get to certain parts but a lot of steps are skipped when people explain things. By taking the integral it certainly makes more sense now.
If an object starts from rest and accelerates, then a plot of its velocity over time is a line, starting at zero with a slope equal to the acceleration.
The distance traveled is the area under the velocity vs. time graph. That area under the sloped line is a triangle. The base of the triangle is the time, the height is the final velocity, or the acceleration*time, and so the area is
[itex]a = \frac{1}{2}base*height = \frac{1}{2}t*at = \frac{1}{2} at^2[/itex]
If acceleration is constant, then you can derive the formula using algebra
Δt = t1 - t0
v1 = v0 + a Δt
average velocity (if acceleration is constant):
vavg = 1/2 (v0 + v1)
distance:
d1 = d0 + vavg Δt
d1 = d0 + 1/2 (v0 + v1) Δt
d1 = d0 + 1/2 (v0 + (v0 + a Δt)) Δt
d1 = d0 + 1/2 (2 v0 + a Δt)) Δt
d1 = d0 + v0 Δt + 1/2 a Δt2
"If acceleration is constant, then you can derive this using algebra"
To be a derivation starting from the fact of constant acceleration, you'd have to prove the equation about average velocity rather than taking it for granted.
meichenl said:
"If acceleration is constant, then you can derive this using algebra" To be a derivation starting from the fact of constant acceleration, you'd have to prove the equation about average velocity rather than taking it for granted.
This can be done geometrically using a graph, time on the x-axis, velocity on the y-axis.
define delta t and midpoints:
Δt = t1 - t0
tmid = 1/2 (t0 + t1)
vmid = 1/2 (v0 + v1)
Assume zero acceleration, constant velocity. Draw the graph from {t0, vc} to {t1, vc}. Then area_under_line = vc x Δt = velocity x time = distance.
For constant acceleration, the midpoint of the line {t0, v0} to {t1, v1} occurs at {tmid, vmid}. The geometric area under the line {t0, v0} to {t1, v1}, can be rerranged by moving the triangle shaped area above the horizontal line vmid to the triangle shaped gap under below the horizontal line vmid, to create a rectangle of area = vmid x Δt = distance. Since average velocity = distance / time, then average velocity = vmid = 1/2 (v0 + v1).
  • · Replies 49 ·
  • · Replies 16 ·
  • · Replies 23 ·
  • · Replies 21 ·
