Water pressure in a tank problem
The problem involves calculating the minimum pressure required at the bottom of a water tower that is 15 meters tall, with considerations for the weight of the water and atmospheric pressure. The context is fluid mechanics, specifically relating to hydrostatic pressure.
  • Exploratory, Assumption checking
  • Participants discuss the appropriate equation for calculating pressure and whether the units used (pascals or atmospheres) affect the outcome. Some question the correctness of their calculations and whether atmospheric pressure should be included in the final result.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some have provided guidance on the use of the pressure formula, while others are questioning their understanding of the problem setup and the inclusion of atmospheric pressure.
There is a mention of the assumption that 1 liter of water equals 1 kg, and the conversion between units of pressure (bar to kg/cm²) is noted. Participants are also reflecting on the implications of not factoring in atmospheric pressure in their calculations.
ar202
A water pipe feeds a water tower with water. The tower is 15 metres tall.
If the water is to flow into the tank what is the minimum pressure of water at the bottom of the tower?
Assume litre of water = 1 kg
Assume 1 BAR = 1kg cm-2
P = p g h ?
am i using the correct equation...?
sooooooooo...
1000 * 9.81 * 15 = 147150 or 1.45 atmopspheres? :rolleyes:
It doesn't matter if you use pascals or atmospheres. And the formula is correct.
ah okay, thanks. Is the answer correct?
Either you didn't express yourself good enough or you're asking a stupid question. :)
hah :redface:
turns out i got this WRONG! any thoughts?!
Apparently You had to count in air pressure (10^5 pascals) since it can still exert pressure on the bottom...Is it correct with that added?
Yeah you're right, i didn't factor in surface pressure. doh!
