Statics - Balancing moment and resultant force
The discussion focuses on solving a statics problem involving the replacement of a force system with a resultant force and determining its intersection with line segment AB from point B. The user calculated a resultant force of 542N at an angle of 10.6 degrees but struggled with summing the moments correctly. A key insight provided is the distinction between resultant linear force and the moment of a couple, which must be accounted for to accurately find the line of action of the resultant force.
  • Understanding of static equilibrium principles
  • Knowledge of force components and resultant forces
  • Familiarity with moment calculations in statics
  • Ability to analyze force systems and their interactions
  • Study the concept of resultant forces in static systems
  • Learn about calculating moments and their effects on structures
  • Explore the principles of couples and their impact on force systems
  • Practice solving statics problems involving multiple forces and moments
Students and professionals in engineering, particularly those studying statics, mechanics, or structural analysis, will benefit from this discussion.
lax1113
Replace the force system with a resultant and specify where its line of action intersects AB from point B.
so I guess the imagine didn't work...
http://yfrog.com/htstaticspicp
I realize it is very small I apologize for that, if anything in the picture is unclear please let me know.
Fresultant = sum of Forces
Moment = sum of Moments
I have solved the components of the X and Y forces of each of the 3 forces and got a resultant of 542N and also got the angle of inclination of this resultant, as 10.6 degrees. However, I am not getting the right answer when I sum the moments. Since it wants where this would be along AB, I set up my moment equation as 533N (the y portion of F resultant) * y = {sum of all of the moments that are acting perpendicular to the line segment AB}. However, I am not getting the correct answer? Is this the right way to go about this problem?
Hi lax1113! :smile:
I think you're missing that there's a resultant (linear) force and a couple (a disembodied moment).
The moment of the couple is the same about any point, and you'll need to subtract it before you can find the line of the resultant (linear) force. :wink:
  • · Replies 105 ·
