Exploring Holomorphic Functions in Complex Analysis
  • Thread starter Thread starter Firepanda
    Functions
The discussion revolves around the properties of holomorphic functions in complex analysis, specifically focusing on the function e^z and its implications for related functions like cosh(z). Participants are exploring the criteria for holomorphicity without relying on limits, instead considering the Cauchy-Riemann equations and power series representations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are questioning whether demonstrating that the derivative of e^z equals e^z is sufficient to conclude that e^z is holomorphic. There is also discussion about the use of the Cauchy-Riemann equations and the challenges in applying them to cosh(z). Some participants express uncertainty about splitting functions into their real and imaginary components.
The conversation is ongoing, with participants providing guidance on using the Cauchy-Riemann equations and discussing the implications of holomorphic functions. There is a recognition of the relationship between e^z and cosh(z), but no consensus has been reached on the best approach to demonstrate holomorphicity.
Participants have mentioned constraints such as avoiding limits and the need to adhere to specific definitions of holomorphicity. There is also an acknowledgment of prior knowledge regarding power series and the properties of holomorphic functions.
Firepanda
I'm not too sure how to show this. Perhaps if I show d(ez)/dz = ez then does this conclude that ez is holomorphic on all of C?
Why does d/dz(e^z)=e^z show e^z is holomorphic? Or at least, why are you saying you aren't sure this shows it's holomorphic?
I suppose I should be using the cauchy riemann equations then?
I was told not to use limits here so I didn't want to use the base definition of holomorphic-ness.
Because in my notes he mentioned the power series
Sure, use Cauchy-Riemann. That's easy enough. Then you'd want to show e^(-z) is also holomorphic. Do you know the sum of holomorphic functions is also holomorphic? If not then you could just directly show cosh(z) is holomorphic using CR.
i tried to use C-R, but I'm unable to split it up into
U(x,y) or V(x,y)
using z=x+iy into cosh(z)
U(x,y) or V(x,y)
How about e^z? Can you split that up?
Dick said:
How about e^z. Can you split that up?
exeiy
= ex(cosy + i.siny)
=excosy + i.exsiny
The C-R satisfy this and so it is holomorphic on all of C? so this would immediatly imply cosh(z) is entire?
And I would check if it were true for e-z as well.
Firepanda said:
exeiy
= ex(cosy + i.siny)
=excosy + i.exsiny
Sure, check e^(-z) as well. It's almost the same thing. I'm a little puzzled why you can split e^(z) and e^(-z) up and not cosh(z). You already said cosh(z)=(e^z+e^(-z))/2.
ah ye that would make more sense if i did it directly, thanks!
  • · Replies 16 ·
