Differential equations, qualitative solution
The discussion revolves around the qualitative analysis of the solution to the differential equation dy/dt = -ty^2 with the initial condition y(0) = 1, specifically over the interval 0 <= t <= 2. Participants are exploring the behavior of the solution and its relationship to equilibrium solutions.
  • Participants are questioning why the solution cannot become zero and remain there, considering the implications of crossing the t-axis. There is also discussion about the derivative and its role in understanding the solution's behavior.
The discussion is ongoing, with participants exploring different interpretations of the solution's behavior. Some have provided insights into the implications of the solution being zero, while others are seeking further clarification on the conditions under which the solution can approach zero.
There is an emphasis on understanding the nature of equilibrium solutions and the implications of the solution's behavior near the t-axis. Participants are navigating assumptions about the solution's continuity and the conditions under which it can reach zero.
MaxManus
dy/dt = -ty^2 y(0) = 1
What can you say about the solution over the interval 0<=t <=2?
The text says that the solution is decreasing and never zero because y(t) = 0 for all t is an equilibrium solution.
I can see why the solution can never cross the x-axis, but why can't the solution become zero?
What did you get for the solution y(t)?
I got y = [tex]\frac{1}{t^2 + 1}[/tex], but I got the impression that looking at the derivative was enough to make the conclusion
Anyone?
MaxManus said:
Anyone?
if it crosses the t-axis, then shouldn't y=0 ? and what does that mean?
Yes, but why can't it become zero and stay there?
How exactly would it become zero? That would mean that at some value of 't' the corresponding value of 'y' would be zero.
[tex]0 = \frac{1}{t^2+1}[/tex]
You would end up with a false equality, which can only mean that y(t) is never zero for all values of t.
  • · Replies 27 ·
