Photons transfer energy to the atoms in the metal plate?
The discussion revolves around how photons transfer energy to atoms in a metal plate when sunlight strikes it, focusing on the mechanisms of energy transfer, the nature of photons, and the resulting effects such as heating and electron excitation. The scope includes theoretical considerations, conceptual clarifications, and some mathematical reasoning related to energy and momentum.
  • Some participants propose that photons, despite being massless, can transfer energy through collisions with atoms, leading to increased atomic vibrations and heating.
  • Others argue that photons possess kinetic energy and can excite electrons to higher energy levels, which may contribute to heating when they return to lower levels, emitting energy in the form of heat.
  • A participant questions the relationship between masslessness and kinetic energy, leading to a clarification that photons have energy but no rest mass.
  • Some contributions emphasize the role of electric fields in the interaction between photons and atoms, suggesting that these fields cause atomic movement.
  • There is a discussion about the concept of relativistic mass, with differing views on whether photons should be considered to have mass in any form.
  • One participant describes the photoelectric effect, explaining how photon energy relates to electron excitation and the conditions under which electrons can be emitted from the metal.
  • Confusion arises regarding the terms "hitting" versus "absorbing" in the context of photon interactions with electrons.
  • Mathematical expressions for photon energy are presented, including equations relating energy to frequency and wavelength, as well as conditions for the photoelectric effect.
Participants express a range of views on the nature of photons and their interactions with atoms, with no consensus reached on the definitions of mass and energy transfer mechanisms. The discussion remains unresolved regarding the implications of relativistic mass and the precise nature of photon-atom interactions.
Limitations include varying interpretations of mass and energy transfer, dependence on definitions of kinetic energy and mass, and unresolved mathematical steps related to photon interactions.
wolram
Dearly Missed
When sunlight hits an object, for instance a metal plate, the plate will
get hotter, now as i understand, heat is caused by atoms vibrating, so
the photons hitting the metal plate must have caused the atoms in it
to vibrate, my question is, how do massless? photons transfer energy
Science news on Phys.org
The photons have no rest mass, but they do have energy (kinetic energy). Therefore when the photon collides with the atom, I presume it would transfer some of this kinetic energy to the atom which could heat it up.
Petrushka
I must admit that i am stupid, i did not realize that if something is massless, that
it could have kinetic energy, is this related to relativistic mass?
No no no no. No relativity here. No stupidity either. That is pretty much what is special about photons, they have energy but no mass. If we speak of photons, then the energy of the IR beam is E = hNf (Planck's constant x number of photons x frequency of the photons). But we don't even need Plank. You know about electric fields? A beam of light is a wave of electric fields (and magnetic but not important for now). When the electric fields reach the metal, they make its atomes and electrons move, like any field does. Relations for the energy of a EM wave can be derived from Maxwell's work.
wolram said:
Petrushka
Even photons have mass. Many people call that mass relativistic mass. In such a collision of photon with atom the sum of the (relativistic) mass is conserved. Momentum is conserved too and photons have momentum. If the atom absorbes the photon then the atom will be in a higher energy state. That is not called an increase in heat. Heat pertains to a collection of particles like a solid made of atoms or a gas of atoms etc.
Pete
when a photon hits a metal plate, the photon hits an electron and sends it to a higher energy level and then back down to its original level emitting another photon. This is why metals are shiny. Is it this oscillation from one energy level and back that causes the heat to be produced?
Thanks for the replies so far, but I am still confused between the,
photon "hitting", an electron, as in a collision between two bodies,
and the atom "absorbing", the energy of the photon.
Heat is also photons. Suppose a visible photon makes an electron go from level 2 to level 8. The electron may well drop back to level 6, then 4, then 2 again, emmiting 3 lower energy (= IR = heat) photons instead. This is why the color black is hot. Metals are shiny because they reflect the photons. they bounce back without any electrons changing levels.
pmb_phy, photons have momentum, but no mass (Not in conventionnal theories anyway, and I would need a very good reference to be convinced if it did in even in TOE efforts). Relativistic mass is the mass of an object when it is moving very fast, which is a function of the object's mass at rest. In the case of a photon, they are both zero. The problem from wolram's first post doesn't seem to have anything to do with relativity and should be completely answerable without it.
Gonzolo said:
pmb_phy, photons have momentum, but no mass ..
I said they have relativistic mass. They don't have rest mass.
Inertial mass, (aka relativistic mass), m, is defined such that mv is a conserved quantity. Momentum is then defined as p = mv. Therefore anything that has momentum has relativistic mass - by definition. Any decent relativity text will tell you that.
Pete
when the photon hits the electron, the electron is in a discreet energy level in which it stays in by the attractive elecromagnetic force towards the positively charged nucleus. Once the photon hits, it may give the electron enough energy to escape this energy level and to go into a higher energy level, (further from the nucleus). This photon, if it has enough momentum can even knock out the electron totally out of the metal (photoelecric effect) or it can have a low enough energy and just bounce off the electron causing no effect. Its not hard to understand. The energy of the photon is
[tex]E=nhf \\[/tex]
[tex]E=energy\ n=integer \\[/tex]
[tex]h=planck's\ constant\ = 6.63x10^{-34J/s}\\[/tex]
[tex]f=frequency\\[/tex]
or
[tex]E = \frac{hc}\lambda \\[/tex]
This energy equation wan be used to determine what will happen when the photon hits the metal. For example, the photoelectric effect can be determined weather it will occur or not.
[tex]E = W_o + E_k[/tex]
[tex]W_o = work\ function\ of\ the\ metal[/tex]
[tex]E_k = kinetic\ energy\ left\ after\ collision\ with\ electron[/tex]
if the energy of the photon is equal to or greater than the work function of the metal, then the photoelectric effect will occur, if it is a lot greater, then the effect will occur and the electron will have a lot of kinetic energy left over. If the photon's energy is less than the work function, then the electron will oscilate.
Thankyou Nenad.
...and thanks pmb_phy, I'll check on that.
  • · Replies 22 ·
  • · Replies 38 ·
