Projectile Motion- Horizontal Range and Time of Flight
The problem involves projectile motion, specifically calculating the horizontal range and time of flight for bullets fired at different angles from a rifle. The initial speed of the bullets is given as 200 m/s, and the angles of projection are 60° and 45° above the horizontal.
  • Conceptual clarification, Mathematical reasoning
  • The original poster attempts to apply the equations for horizontal range and time of flight but expresses uncertainty about using the initial speed as the value for velocity in the equations. Some participants suggest reviewing the proofs of the equations to enhance understanding.
The discussion is ongoing, with some participants providing clarification on the use of initial velocity in the equations. There is a recognition of the original poster's confusion regarding the application of the given speed in the calculations.
The original poster is unsure if they need to derive the initial velocity from the provided information, which may indicate a misunderstanding of the problem setup.
leah3000
A rifle is used to fire two bullets. The first shot is at an angle of 60° above the horizontal and the second at an angle of 45° above the horizontal. The speed of EACH bullet as it leaves the rifle is 200ms^1. For EACH bullet calculate the horizontal range and the corresponding time of flight.
Horizontal Range: v^2sin2ө/ g
Time of Flight= 2vsinө/g
Horizontal Range for 1st shot= (200^2)sin2(60)/9.81
=3531m
Time of Flight= 2(200)sin(60)/9.81
=35.3 secs
Horizontal Range for 2nd shot= (200^2)sin2(45)/9.81
=4077m
Time of Flight= 2(200)sin(45)/9.81
= 28.8 secs
I'm not sure if I'm supposed to use the 200 as v or if I'm to calculate v somehow from the given information.:confused:
You have used the equations correctly. I guess you are just not sure how the equations work? Maybe reading the proofs of these equations would help.
ok...i just keep thinking that since it left the rifle at 200ms^1that that would be the initial velocity, u. I wasn't too sure if I could use it in the equation as v. I thought that i some how had to calculate it but then there would be more than one unknowns when using the equatios of motion:redface:
ok...i just keep thinking that since it left the rifle at 200ms^1that that would be the initial velocity, u. I wasn't too sure if I could use it in the equation as v. I thought that i some how had to calculate it but then there would be more than one unknowns when using the equations of motion:redface:
v represents initial velocity, so it should be 200 m/s.
ok thank you
28K
