Interperating a graph with logarithmic scales
  • Thread starter Thread starter ehilge
    Graph Logarithmic
The discussion revolves around interpreting a graph that utilizes logarithmic scales, specifically in the context of determining time values based on intervals represented on the graph. The original poster expresses confusion regarding the reading of logarithmic scales and seeks clarification on their approach to the problem.
  • The original poster attempts to calculate time values based on logarithmic intervals and questions the accuracy of their method. They inquire about potential interpolation techniques for greater precision and whether there are better approaches to the problem.
Some participants provide feedback on the original poster's calculations, suggesting that while they are on the right track, there may be inaccuracies in their time estimates. There is a recognition of the need for precision in measurements, and a suggestion is made to use a ruler for more accurate data points.
The original poster mentions specific temperature values and the use of intervals in their calculations, indicating a structured approach to interpreting the graph. However, there is an acknowledgment of potential limitations in measurement precision when working with logarithmic scales.
ehilge
see attachment
log10x=y
10y=x
Since I'm rather confused on reading a logarithmic scale, I thought I'd post this to see if I'm doing this right and/or if there's a better way to do the problem.
a) T=500 C
using the # of intervals we can say that if d=.01, x=.5 intervals so...
log(t)=.5
t=3.16 min
similarly for d=.1
log(t)=3.5 intervals
t=3162
change in time = 3162-3.16 = 3158.8min
b) same process but use x=-.5 intervals and x=2.1
If this method does work, is there any way to interpolate values so I can be more exact? or is there a better way to do the problem in general?
thanks!
I think you're on the right track, but maybe just a little off. For the 500 degree track (part a), the starting time is about 3.2 min, but the ending time looks to me like about 3.6, which corresponds to about 4000 min. Subtracting gives a duration that's again close to 4000 min. Unless you can really measure the position of the points very precisely, it doesn't make sense to end up with answers with more than one or two places of precision.
yah, I was worried about being able to get a precise enough answer to matter. I think later I'll find a ruler and figure out more exact data points
thanks!
Yes, a ruler would help you get more precise answers.
17K
  • · Replies 20 ·
  • · Replies 18 ·
