Why is the applied force inward for a spring
The discussion revolves around the work done on a block connected to a spring as an external force is applied to move the block slowly from a negative maximum position to zero. The problem involves understanding the relationship between the applied force and the spring force, particularly in the context of work done and the direction of forces.
  • Participants explore the relationship between the applied force and the spring force, questioning the direction of these forces during the movement of the block. There is a focus on understanding why the applied force is described as pushing inward and how this relates to the spring's tendency to expand or contract.
Some participants express confusion about the terminology used in the context of the applied force and its direction relative to the spring's behavior. There is an ongoing exploration of the concepts of work and force direction, with references to illustrations and textbook explanations. No consensus has been reached, but various interpretations are being discussed.
Participants are grappling with the definitions of forces in relation to the spring's natural length and the implications of compressing or stretching the spring. The discussion is framed within the constraints of a homework problem, which may limit the information available for a complete understanding.
jwxie
Consider the work done on the block by an external agent as the agent applies a force on the block and the block moves very slowly from xi = -x max to xf = 0.
W = Fs * dr = integral of (-kx) * dx from xi to xf
The book illustrates F applied to the left, and Fs to the right.
"We can calculate this work by noting that at any value of the position, the applied force is equal in magnitude and opposite in direction to the spring force Fs if it moves at a very slow speed. Fapp = -Fs = -(-kx) = kx
Therefore, the work done by this applied force on the block-spring system is like the following integral as shown in the picture:
http://i43.tinypic.com/24d4lee.jpg
http://i39.tinypic.com/dw6onl.jpg
My question:
1. Was the illustration above a demonstration of the phenomena that if we carry the spring by the applied force very slowly, in theory and ideally, the applied force (which is pulling toward the right) is exactly the opposite of Fs?
But further more, the book continues:
"The work is equal to the negative of the work done by the spring force for this displacement." <--- I think this satisfy my comment above, yet
"The work is negative because the external agent must push inward on the spring to prevent it from expanding and this direction is opposite the direction of the displacement of the point of application of the force (F*r) as the block moves from -Xmax to zero."
I can understand everything except the phrase in bold. We applied the force outward (pulling it to the right, if I am correct).There the Fs due to the constant k, has tendcy to move backward, am I correct?
2. If I am, then why is this applied force pushing inward? And what exactly is this "expanding"?
Thanks
It is equal to the word done by you to move the body from 0 to intial position, but this time the answer is +ve
sorry for being very lazy to read all you have wrote but I think it is -x max so the spring try to expand and so you have to pull it back to stop it from expanding.
If you have already compressed the spring below its "natural length", then the force due to the compression of the spring is outward and so you need to apply equal force inward to keep it from expanding to its natural length.
If you have already stretched the spring beyond it "natural length", then the force due to the stretch of the spring is inward and so you need to apply equal force outward to keep it from contracting to its natural length.
  • · Replies 30 ·
