Calculate Distance Travelled by Einsteinian Meter Rod in 1.9245-09 Seconds
  • Context: Graduate
  • Thread starter Thread starter zoobyshoe
The discussion revolves around calculating the distance traveled by an Einsteinian meter rod moving at a speed of 0.5c over a specified time interval of 1.9245-09 seconds. Participants explore various aspects of the calculation, including the implications of scientific notation and the effects of special relativity on distance measurement.
  • One participant states that the Einsteinian meter rod travels at 0.5c and asks how to calculate the distance it travels in 1.9245-09 seconds.
  • Another participant suggests a basic formula for distance calculation, using the provided time and a speed derived from the rod's travel time.
  • Concerns are raised about the interpretation of the time measurement, specifically whether 6.66667-09 is meant to be in scientific notation or a peculiar calculation.
  • Several participants discuss the implications of using scientific notation and clarify the difference between 6.66667-09 and 6.66667 x 10-9.
  • One participant emphasizes the need to consider special relativity in the calculation, noting that distance contracts at high speeds.
  • Another participant questions the clarity of the problem statement regarding the reference frame for speed and time measurements.
  • A hypothetical scenario is presented using non-relativistic speeds to illustrate the same calculation method.
  • Further mathematical expressions are shared, demonstrating different ways to represent calculations involving scientific notation.
Participants express differing views on the necessity of applying special relativity to the problem, with some arguing it is essential while others suggest it complicates the issue unnecessarily. There is no consensus on the interpretation of the time measurement or the correct application of scientific notation.
Participants highlight potential ambiguities in the problem statement, particularly regarding the reference frame for speed and time, and the representation of numbers in scientific notation. These factors may affect the calculations and interpretations presented.
zoobyshoe
I have an Einsteinian meter rod traveling at .5c which is 1 meter per 6.6667-09 seconds.
How do I discover how far the rod will travel in 1.9245-09 seconds?
Mathematics news on Phys.org
(meters/second) X seconds = meters
so 1.9245/6.6667 =
so 1.9245/6.6667 =
.288673557 meters in 1.9245-09 seconds.
Thanks, Ivan. I'm just beginning to calculate with sci notation and get dazzled by the new appearance of things (very slow brain for math).
Hold on for a moment: is that 6.66667-09 (which would be a peculiar calculation) or 6.66667x10-9 ("scientific notation"). Those are very different numbers!
A couple of years ago Edexcel wrote in the exams book that the gravitational constant = 6.67300 × 11-11
It would look like this written out:
.0000000066667
I've been using 6.66667-09 to indicate this in a thread and no one has said anything about it, although everyone else is writing it the way you do. I just figured they were interchangable.
If not, then I'm curious to find out what interesting thing I have been indicating without realizing it.
.0000000066667
6.66667-09 ≈ 0.0000000384432
6.66667 x 10-09 = 6.66667e-09 = 0.00000000666667
.0000000066667
You have been indicating the reciprocal of the 9th power of 20/3 (or 6.66667)...but that would be a very unusual representation, given the context.
So, everyone understood what you meant, or what you meant to mean.
I think you need to use SR in this question, since distance contracts when traveling at high speed.
[tex]d=vt[/tex]
[tex]d\sqrt {1- \frac{(0.5c)^2}{c^2}}=(0.5c)(6.66667 x 10^(-9))[/tex]
and solve for d from then on.
[tex]d=vt[/tex]
Yes, using relativist speeds in this problem (to confuse the issue) didn't seem like a particularly good idea for someone struggling with basic scientific notation.
But if this is indeed meant to be a relativistic problem then it is inadaquately stated. The speed of 0.5c is measured relative to who? This time of 1.9245 x 10^(-09) is measured relative to who? If the speed, time and distance are all measured in a consistent reference frame then the distance traveled (in that same reference frame) will still be sucessfully computed by d = vt.
I can state the same problem in terms of non-relativistic speeds:
If I have a dragonfly which is flying straight and steady at a rate of 1 meter per .0493 seconds, how do I determine how far it will fly in 1.9245x10-9 seconds?
d= vt=1 1 m/(0.0493 sec)*1.9245x10-9= (1.9245/0.0493)x10-9= 25.4349 x10-9.
Since the "least accurate" number (0.0493) had 3 significant figures, I would write that as 2.54x10-8 meters.
Thanks HallsofIvy. I'm interested in the way you expressed this, with the single exponent outside the parenthesis. It makes me wonder how you would put it if both had an exponent, say if .0493 had been 4.93x10-7.
[tex] \frac{1.9245 \times 10^{-9}}{4.93 \times 10^{-7}}\ =<br /> \ \frac{1.9245}{4.93} \times \frac{10^{-9}}{10^{-7}}\ =<br /> \ (1.9245/4.93) \times 10^{-2}[/tex]
  • · Replies 55 ·
  • · Replies 21 ·
  • · Replies 18 ·
13K
  • · Replies 18 ·
