Moment Problem: Unique Solution for Power Series g(x)=∑a(n)(-1)^nx^n
  • Context: Graduate
  • Thread starter Thread starter zetafunction
    Sequence
The discussion revolves around the uniqueness of solutions to a moment problem defined by a power series \( g(x) = \sum_{n \ge 0} a(n)(-1)^{n} x^{n} \) and its relation to an integral equation involving an unknown function \( f(x) \). Participants explore whether the positivity of \( f(x) \) over the interval \( (0, \infty) \) guarantees a unique solution for the coefficients \( a(n) \).
  • One participant proposes that if \( f(x) > 0 \) on the interval \( (0, \infty) \), then the solution to the integral equation \( a(n) = \int_{0}^{\infty} f(x) x^{n} \, dx \) is unique.
  • Another participant questions the clarity of the original post, noting that the integral equation was not clearly labeled and expressing confusion about the relationship between the integral of \( f(x) \) and the sum defining \( g(x) \).
  • A later reply clarifies the intent of the original question, emphasizing the uniqueness of the solution for \( a(n) \) under the condition that \( f(x) \) is positive.
  • One participant challenges the limits of the integral, suggesting that it should start at \( x = 0 \) rather than \( n = 0 \).
Participants express differing views on the clarity and correctness of the formulation of the problem, with some agreeing on the uniqueness condition while others raise questions about the setup and notation. The discussion remains unresolved regarding the specifics of the integral's limits and the implications of the positivity condition.
There are limitations regarding the clarity of the original problem statement, particularly in the labeling of equations and the definition of the integral's limits. The discussion also reflects uncertainty about the implications of the positivity of \( f(x) \) on the uniqueness of the solution.
zetafunction
given the sequence (power series) [tex]g(x)= \sum_{n\ge 0}a(n)(-1)^{n}x^{n}[/tex]
if i define [tex]a(n)=\int_{n=0}^{\infty}dxf(x)x^{n}[/tex] (1)
if [tex]f(x)>0[/tex] on the whole interval [tex](0,\infty)[/tex] , is the solution to (1) unique ?? , this means that the moment problem for a(n) would have only a solution.
How can we tell you if "the solution to (1)" is unique when there is nothing labeled (1)?
And what does an integral of f(x) have to do with a sum of g(x)?
Frankly, nothing here makes any sense.
i meant
is the solution to
[tex] a(n)=\int_{n=0}^{\infty}dxf(x)x^{n} [/tex]
where a(n) is given but f(x) is unknown UNIQUE is f(x) is positive on the whole interval (0,oo) ? , i mean if the integral equation
has ONLY a solution provided f(x) is always positive, thanks.
I don't think your integral should start at n=0 should it? Maybe x=0 ...
  • · Replies 21 ·
  • · Replies 0 ·
