| New Reply |
2nd Order Runge-Kutta: 2nd Order Coupled Differential Equations |
Share Thread | Thread Tools |
| Mar13-10, 04:33 AM | #1 |
Consider the system of coupled second-order differential equations [tex]u''-(t+1)(u')^2+2uv-u^3=\cos{t}[/tex] [tex]2v''+(\sin{t})u'v'-6u=2t+3[/tex] with initial conditions u(0)=1, u'(0)=2, v(0)=3, v'(0)=4. Use the second order Runge-Kutta method with h=0.2 and a=2/3, b=1/3, [tex]\alpha=\beta=3/2[/tex] to find u, u', v, v' at t=0.2 2. Relevant equations For the equation dy/dx=f(x,y) [tex]y_{n+1}=y_n+ak_1+bk_2[/tex] [tex]k_1=hf(x_n,y_n)[/tex] [tex]k_2=hf(x_n+\alpha h,y_n+\beta k_1)[/tex] 3. The attempt at a solution I have no background in Differential Equations but some searching around on the net gave me a little bit of insight and I believe I'm supposed to change the two given equations into 4 separate first-order ODE's. So what I have is as follows: Rearranging the two 2nd order equations gives [tex]u''=\cos{t}+(t+1)(u')^2-2uv+u^3 [/tex] [tex]v''=t+\frac{3}{2}-\frac{1}{2}(\sin{t})u'v'+3u[/tex] If we now let [tex]u'=x[/tex] [tex]v'=y[/tex] then [tex]u''=x'[/tex] [tex]v''=y'[/tex] and we have [tex]u'=f(x)=x[/tex] [tex]v'=m(y)=y[/tex] [tex]x'=g(t,x,u,v)=\cos{t}+(t+1) (x)^2-2uv+u^3[/tex] [tex]y'=n(t,x,y,u)=t+\frac{3}{2}-\frac{1}{2}(\sin{t})xy+3u[/tex] Furthermore [tex]u(0)=1[/tex] [tex]u'(0)=x_0=2[/tex] [tex]v(0)=3[/tex] [tex]v'(0)=y_0=4[/tex] so that [tex]k_{1u}=hf(x_0) =(0.2)f(2) =(0.2)(2) =0.4[/tex] [tex]k_{1v}=hm(y_0) =(0.2)m(4) =(0.2)(4) =0.8[/tex] [tex]k_{1x}=hg(t,x_0,u,v) =(0.2)g(0,2,1,3) =(0.2)[1+(2)^2-2(1)(3)+(1)^3] =0[/tex] [tex]k_{1y}=hn(t,x_0,y_0,u) =(0.2)n(0,2,4,1) =(0.2)[(0)+\frac{3}{2}-(0)+3(1)] =0.9[/tex] Assuming all of the above is correct then, well, what now? Do I say, e.g. [tex]k_{2u}=hf(x_0+\alpha h)[/tex] [tex]k_{2v}=hm(y_0+\alpha h)[/tex] or is it supposed to be [tex]k_{2u}=hf(x_0+\alpha k_{1u})[/tex] [tex]k_{2v}=hm(y_0+\alpha k_{1v})[/tex] ? And what about [tex]k_{2x}[/tex] and [tex]k_{2y}[/tex], each of which has four variables? Thanks for your help! phyz |
| Mar13-10, 04:57 AM | #2 |
Try thinking of your Runge-Kutta equations as a vector equation, with yk having four components (u,v,x,y), and with the dependent variable, xx = tk. So at each time step, you need to calculate all four components of the vector, and plug them into the Runge-Kutta formula. You might want to rename x and y as z and w so you don't get confused so then you'll have yk = (u,v,z,w) ), since the x and y in your diff eqs are different from the x and y in the Runge-Kutta formula.
| Mar13-10, 12:50 PM | #3 |
Right, let's rewrite the Runge-Kutta equations in terms of z and w then:
[tex]z_{n+1}=z_n+ak_1+bk_2[/tex] [tex]k_1=hf(w_n,z_n)[/tex] [tex]k_2=hf(w_n+\alpha h,z_n+\beta k_1)[/tex] If we have to increment the value of the independent variable with h and that of the function values with those of the previous k values, then we should have [tex]k_{2u}=hf(x_0+\alpha h)[/tex] [tex]k_{2v}=hm(y_0+\alpha h)[/tex] since from f(x) and m(y) we have x and y as independent variables (?) Which would then mean that, in the functions g(t,x,u,v) and n(t,x,y,u) the variables t,x,y are independent and u,v are function values? I really need an example of a similar problem to help me figure this out... ![]() Please tell me which bits of what I've done so far are correct. Cheers! |
| Aug4-11, 05:03 AM | #4 |
Have anyone been able to solve this. I have been stuck on the same question now for days at about the same place.
Help would really be appreciated. |
| New Reply |
| Thread Tools | |
Similar Threads for: 2nd Order Runge-Kutta: 2nd Order Coupled Differential Equations
| first order coupled differential equations | Differential Equations | 11 | ||
| Reducing third order ODE to a system of first order equs + 4th order runge-kutta | Differential Equations | 1 | ||
| Reducing third order ODE to a system of first order equs + 4th order runge-kutta | Calculus & Beyond Homework | 0 | ||
| Coupled first order differential equations | Differential Equations | 5 | ||
| Coupled first order differential equations | Differential Equations | 2 | ||
