What are some distinguishing properties between electric and magnetic fields?
The discussion revolves around the distinguishing properties between electric and magnetic fields, exploring their differences, interactions with charged particles, and potential deeper connections. Participants examine theoretical aspects, practical implications, and the underlying principles governing these fields.
  • One participant notes that electric fields are created by charged particles, while magnetic fields arise from the relative motion of charged particles, questioning if other distinguishing properties exist.
  • Another participant explains that the Lorentz force law describes how test charges in electric and magnetic fields experience forces, emphasizing that magnetic forces act at right angles to velocity and do not slow particles down.
  • A participant discusses the nature of acceleration in electric and magnetic fields, suggesting that both fields correspond to different types of accelerations and hinting at deeper connections between them.
  • Further, it is mentioned that Faraday's law indicates a time-varying magnetic field can produce an electric field, linking the two types of fields through electromagnetic principles.
  • One participant points out the absence of magnetic analogues to electrically charged particles, referencing Maxwell's equations and the concept of magnetic monopoles as a theoretical possibility.
  • Another participant introduces the idea of weak/strong duality, suggesting that theories with magnetic sources can be related to those with electric sources through a specific symmetry.
Participants express various viewpoints on the properties and relationships between electric and magnetic fields, indicating that multiple competing views remain without reaching a consensus on deeper connections or implications.
Some discussions involve assumptions about the behavior of particles in fields and the theoretical implications of electromagnetic theories, which may not be fully resolved within the conversation.
Hyperreality
Okay, I know the difference between an electric field and a Magnetic field:
An electric field can created by a presence of a charged particle such as elctron or proton. While a magnetic field is created due the relative motion of a charged particle with respect to a stationary observer, which radiates at right angle to the motion of the charged particle.
But apart from the difference mentioned above, are there any other different properties which we can use to distinguish an electric field from a magnetic field?
For example, suppose we have an unknown force field, and we insert an electron into the force field, can we determine whether the force field as an elctric field or a magnetic field by observing the trajectory of the electron in the force field?
Test charges in an arbitrary superposition of electric and magnetic fields feel forces described by the Lorentz force law:
F = q (E + v x B) where E and B are the electric and magnetic fields, v is the velocity vector of the charge, and q is the charge. 'x' connotes the vector cross product.
As you can see, magnetic forces always act at right angles to the velocity. As a result, magnetic fields never slow particles down -- they just bend them around in circles.
So the answer to your question is an enthusiastic "yes!" -- you can watch the trajectory of a particle and determine whether the field was electric or magnetic simply by seeing if the particle slowed down at all.
- Warren
Ok, I get this. Thx Chroot.
Now the EField changes the speed of the particle radially from it, it accelerates the particle. The MField changes the direction of the particle 'tangentialy', it accelerates it too. You see where I'm going don't you? Both types of fields correspond to both type of accelerations! Now there must be some deeper connections to this right ?
Boy, you catch on fast! Yes, there is a deeper connection, the electric and magnetic fields can be expressed as the electromagnetic field tensor, a single expression which contains all the information about the field at every point in space and time.
You bet there's a deeper connection, JAL. Faraday's law says that a time rate of change in a magnetic field produces an electric field.
In terms of Maxwell's eqns.:
[inte]E*dl = dB/dt Where B is the flux of the magnetic field.
Thus an electromotive force developes as a result of a changing magnetic field.
Creator
It's worth pointing out that as far as we know, there are no magnetic analogues of electrically charged particles, and this is reflected in maxwell's equations by it's characterization of the magnetic field as being divergence free.
However, grand unified theories do predict the existence of magnetic monopoles, but in number densities so small that it's unlikely we'd ever see one.
Nonetheless, we can construct theories with magnetic sources that are related to the conventional ones having electrical sources by a special class of symmetry which is known as weak/strong duality since it relates one theory at strong coupling to the other at weak coupling.
  • · Replies 17 ·
  • · Replies 22 ·
