Can I Power a GEYSER with Calculator Solar Panels?
Connecting 76 calculator solar panels, each producing 3V, in series can generate approximately 228V DC, which is suitable for powering a GEYSER rated at 220V-240V AC. However, the output current from these panels is significantly low, around 0.1A, resulting in only about 0.25% of the power typically required for a standard immersion hot water heater. Therefore, while the voltage is adequate, the insufficient current output limits the effectiveness of this setup for heating water.
  • Understanding of solar panel configurations and voltage generation
  • Knowledge of AC and DC voltage compatibility
  • Familiarity with immersion heater specifications
  • Basic electrical principles, including current and power calculations
  • Research solar panel series connections and their voltage outputs
  • Learn about the specifications and power requirements of immersion heaters
  • Explore alternative solar panel options with higher current outputs
  • Investigate energy storage solutions for solar power applications
Individuals interested in renewable energy solutions, DIY solar power enthusiasts, and those exploring alternative methods for heating water using solar energy.
k.bipin
If i connect 76 solar panels (3v each) (that are found in calculators) together can i generate voltage of about 230v DC? if i connect this voltage to a GEYSER of 220v-240v AC does the GEYSER work
Yes
If a GEYSER is just an immersion hot water heater - yes.
Except if you are talking about little battery charger 10cm square panels, you are only going to get perhaps 0.1A, or about 0.25% of the power you normally use for a water heater
  • · Replies 31 ·
  • · Replies 32 ·
