How Do You Find the PDF of a Ratio of Exponential Random Variables?
The discussion focuses on finding the probability density function (PDF) of the random variable Z defined as z = x/(x + y), where X and Y are independent exponential random variables with parameter 1. The cumulative distribution function (CDF) F_Z(z) is derived through integration of the joint PDF f_{xy}(x,y) = f_x(x)f_y(y). The final result shows that the PDF of Z is z, but the initial approach to derive it was incorrect due to a misinterpretation of the inequality when z > 1. Alternative methods involving the reciprocal of Z are suggested for further exploration.
  • Understanding of exponential random variables and their properties
  • Knowledge of joint probability density functions
  • Familiarity with cumulative distribution functions and their derivation
  • Concept of transformations of random variables
  • Study the derivation of the PDF for the ratio of two independent exponential random variables
  • Learn about the properties of joint distributions and their applications in probability theory
  • Explore the method for finding the PDF of the reciprocal of a random variable
  • Investigate the implications of transformations in probability distributions
Students and professionals in statistics, data science, and probability theory who are working with random variables, particularly those interested in the behavior of ratios of exponential distributions.
dionysian
Let X and Y be two independent random variables each exponentially distributed with parameter 1. Define a new random variable:
[tex]z = \frac{x}{{x + y}}[/tex]
Find the PDF of Z
[tex]\begin{array}{l}<br /> {F_Z}(z) = P(Z < z) = P\left( {\frac{x}{{x + y}} < z} \right) = P\left( {x \le \frac{{zy}}{{1 - z}}} \right) \\ <br /> {F_Z}(z) = \int\limits_0^\infty {\int_0^{\frac{{zy}}{{1 - z}}} {{f_{xy}}(x,y)dxdy} } \\ <br /> {f_{xy}}(x,y) = {f_x}(x){f_y}(y) \\ <br /> {F_Z}(z) = \int\limits_0^\infty {\int_0^{\frac{{zy}}{{1 - z}}} {{f_x}(x){f_y}(y)dxdy = } } \int\limits_0^\infty {\int_0^{\frac{{zy}}{{1 - z}}} {{e^{ - x}}{e^{ - y}}dxdy} } = \int\limits_0^\infty {{e^{ - y}}\left[ {\int_0^{\frac{{zy}}{{1 - z}}} {{e^{ - x}}dx} } \right]} dy \\ <br /> {F_Z}(z) = \int\limits_0^\infty {{e^{ - y}}\left[ { - {e^{ - \frac{{zy}}{{1 - z}}}} + 1} \right]} dy = \int\limits_0^\infty { - {e^{ - y}}{e^{ - \frac{{zy}}{{1 - z}}}} + {e^{ - y}}} dy = \int\limits_0^\infty { - {e^{ - \frac{{y(1 - z) - zy}}{{1 - z}}}} + {e^{ - y}}} dy \\ <br /> {F_Z}(z) = \int\limits_0^\infty { - {e^{ - \frac{y}{{1 - z}}}} + {e^{ - y}}} dy = (1 - z){e^{ - \frac{y}{{1 - z}}}}|_0^\infty - {e^{ - y}}|_0^\infty = z \\ <br /> \end{array}[/tex]
Now i know that if i take the derivative of this i will get the "pdf" but its obviously wrong. Any thoughts?
dionysian said:
[tex]P\left( {\frac{x}{{x + y}} < z} \right) = P\left( {x \le \frac{{zy}}{{1 - z}}} \right)[/tex]
This step is invalid if [itex]z > 1[/itex]. (The inequality gets reversed in that case.)
But you could instead write
[tex]P\left( \frac{x}{x+y} < z \right) = P\left(y > \frac{x(1-z)}{z}\right) = 1 - P\left(y \leq \frac{x(1-z)}{z}\right)[/tex]
I'm not sure if that will be any more helpful, but at least it's correct.
I wonder if it would be helpful to work with the reciprocal:
[tex]\frac{1}{z} = \frac{x + y}{x} = 1 + \frac{y}{x}[/tex]
It shouldn't be hard to work out the pdf of
[tex]\frac{y}{x}[/tex]
as it is the quotient of two independent random variables. Adding 1 just shifts the pdf to the right by 1. Then do you know how to find the pdf of the reciprocal of a random variable with known pdf?
