Can HHO Water4Gas Really Improve Car Mileage?
  • Thread starter Thread starter emagray
    increase
The discussion revolves around the claims that HHO (hydrogen and oxygen) gas produced from water electrolysis can improve car mileage when introduced into the engine intake. Participants explore the theoretical and practical implications of such systems, including their feasibility and the underlying science, while addressing skepticism regarding the validity of these claims.
  • Some participants express skepticism about the claims of significant mileage improvements, suggesting that many online testimonials are either hoaxes or based on errors.
  • There is a theoretical possibility that hydrogen could enhance combustion efficiency by a few percent if the hydrogen generator is efficient, though this may require specialized skills to implement effectively.
  • Concerns are raised about the conservation of energy, with some arguing that the mass airflow (MAF) sensor would limit any potential benefits from HHO gas.
  • One participant suggests that energy produced during braking could be harnessed to generate HHO gas, proposing a kinetic energy recovery system (KERS) as a means to utilize otherwise wasted energy.
  • Another participant questions the practicality of a chemical regenerative braking system, noting the challenges of energy storage and the need for a large alternator to handle energy demands during braking.
  • There are discussions about the potential for using hydrogen in conjunction with other systems, such as thermoelectric generators, to increase overall efficiency, though the energy required to produce hydrogen is acknowledged as a significant factor.
  • Some participants propose that advancements in material sciences, particularly in tires and lubricants, may offer more beneficial improvements in vehicle efficiency than HHO systems.
Participants generally do not reach a consensus, with multiple competing views on the effectiveness and practicality of HHO systems. Skepticism about the claims of improved mileage is prevalent, but some participants explore theoretical benefits and alternative approaches.
Discussions include unresolved assumptions about energy recovery, the efficiency of hydrogen production, and the practical challenges of implementing HHO systems in vehicles. There are also varying opinions on the effectiveness of alternative energy recovery methods compared to HHO systems.
emagray
my uncle has been watching the videos on youtube with all of the people who supposedly gained gas mileage by installing a water electrolizer on their car and running the gases emitted into the intake. now I've tried telling him about the conservation of energy law and how that little bit of HHO gas isn't going to make a difference because the MAF sensor on his car will still tell the ecu to inject just as much gas as it always does, however he believes that because there is such a hype on the internet there has to be some truth to the tale. i can't think of a good explanation of why they get "better" gas mileage other than placebo effect and less aggressive driving but i could be missing something.
does anyone know of these systems and is there any truth to the claim? i am very interested and if it is true i would like to know how it works and want to try it to my car.
The ones you see on youtube that claim massive increases (I've heard like 40%) are either hoaxes or just errors.
However, it is theoretically possible to use hydrogen to improve the combustion efficiency and burn rate by a few percent to get an overall gain of a few percent, if your hydrogen generator is efficient. I can't imagine this could be done by an individual without specialized skills and access to the car's computer to alter the fuel/air mixture.
We have a bunch of threads on the subject you can do a search for, including some with a NASA study on the subject that investigated the combustion improvements I mentioned above.
Hoax. Scam. Avoid.
I looked into these a while back and found (unsurprisingly) that their claims are completely unsubstantiated, and the "science" posted in support of them either makes little or no sense, or else it is unrelated to what happens inside an engine.
SpectraCat said:
Hoax. Scam. Avoid.
So did I and thought the same until I realized there must be some gain when the vehicle breaks, though there is usualy no reference to this effect.
To explain the alternator must act as KERS device when you break.
If you have a HHO device fitted.
So any gas produced will be a bonus which would have gone to waste as heat.
I think you mean "when the vehicle brakes" rather than "breaks"!
Buckley, if a vehicle has a KE recovery alternator system then it would normally charge the battery when braking, so as to reduce the amount of alternator power required during normal driving. This electrical energy is needed to run the ignition and other electrical systems in the car, if you divert it to make HHO then you only have to take more power from the alternator during regular driving. So I fail to see your point.
Yes.
There is a surplus of energy that goes to waste when brakeing.
So much, that a separate alternator could be added to the vehicle that would power a HHO device when brakeing.
The amount of electrical energy needed to run the car is minimal compared to the amount of energy wasted when brakeing which could be recovered and stored.
A chemical regenerative braking systems is possible but hardly the most effective.
You would need a huge alternator to sink anything like the 200Hp energy dump when braking, you need to carry a fresh water source tank, then you have to store a pressurized mix of H2/O2.
A flywheel or a battery would seem like a better bet.
Or you could use an adiabatic expansion gas system linked to a cybernetic control unit with optical inputs - also known as taking your foot of the gas when you see red lights ahead.
Wouldn't the hydrogen use up oxygen in the charge that is needed to combust gasoline faster than the gasoline? I think it makes sense to use oxygen in the heat engine to increase delta T and use hydrogen post combustion in another stage along with more fresh air in conjunction with catalyzed exhaust air. Feed it into a thermoelectric generator and, along with regenerative braking, increase efficiency?
Aside from the theory here it would be interesting if it is economical to build, run, and repair this system type. Hybrids seem to have a favorable cost-benefit ratio AFAIK. And from that perspective, tax the hell out of non-commercial trucks and rear wheel drive vehicles! (http://en.wikipedia.org/wiki/File:Energy_flows_in_car.svg)
Now after typing all this I haven't accounted for the energy needed to split the water molecule :-/ . I think the most beneficial advances are going to be in material sciences in tires and lubricants.
Yes I can see you points.
There could be some advantages though.
I don't imagine a large pressurized tank would be needed to store the mix as long as the fuel was burnt as quickly as possible after it was produced.
Only a small tank would be needed if the water produced after combustion was recovered,
The weight of the alternator would be comparable to flywheel or battery.You might get better storage from a HHO device in as much that more recovered energy could be used more efficiently.
There is nothing more annoying than watching your flywheel run down after you have stoped.
  • · Replies 19 ·
11K
32K
  • · Replies 65 ·
13K
