How Does Lifting a Chain Affect Its Gravitational Potential Energy?
  • Thread starter Thread starter Nivlac2425
    Energy
The discussion focuses on the gravitational potential energy (PE) change of a uniform chain of mass M and length L when lifted from a hook. The increase in gravitational potential energy is calculated as mgL/4, where the center of mass shifts from L/2 to 3L/4. The upward external force F(y) required to lift the chain is related to the mass density and the vertical distance y, necessitating the application of Newton's second law. The work done on the chain can be determined through direct integration of the force function.
  • Understanding of gravitational potential energy concepts
  • Familiarity with Newton's second law
  • Basic knowledge of calculus for integration
  • Ability to analyze free-body diagrams
  • Study the derivation of gravitational potential energy equations
  • Learn how to apply Newton's second law to variable mass systems
  • Explore techniques for integrating force functions in physics
  • Review examples of free-body diagrams in mechanics
Students studying physics, particularly those focusing on mechanics and energy concepts, as well as educators looking to enhance their teaching of gravitational potential energy and force analysis.
Nivlac2425
A uniform chain of mass M and length L hangs from a hook in the ceiling. The bottom link is now raised vertically and hung on the hook.
a. Determine the increase in gravitational potential energy of the chain by considering the change in position of the center of mass of the chain.
b. Write an equation for the upward external force F(y) required to lift the chain slowly as a function of the vertical distance y.
c. Find the work done on the chain by direct integration of F.
PE=W
change in PE= PEf-PEi
a. I found the change in PE from height L/2 to 3L/4 to be mgL/4
b. I understand that this part entails a mass density change, because the length is shortened while the mass stays constant, but I cannot figure out how to write an equation for the F based on this observation.
c. Integration of the force(answer in b.) will equal the answer in a. because PE=W, but I don't have an equation to work with.
Thanks to everyone who look the time to look at this problem!
For b), you're on the wrong track. Density does stay constant because the total length of chain stays constant; you're not significantly stretching or compressing the chain.
Try drawing a free-body diagram on the part of the chain that's being raised--that is, the part between your hand and the lowest part of the U-shaped chain. Then write out Newton's second law, and you'll see what the force is.
I have drawn out the free-body diagram, but it still isn't clicking for me. How do you apply the calculus to this problem? Is mass constantly increasing, requiring more force as the chain is being raised?
