How Do You Use Matrix Inversion to Determine Nutrient Ratios in Food?
The discussion revolves around using matrix inversion to determine nutrient ratios in food, specifically focusing on folic acid, choline, and inositol content in various food types. The original poster presents a matrix equation related to the nutrient amounts required for a laboratory diet for rats.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the setup of the matrix equation Ax = y and the use of the inverse matrix to solve for the nutrient ratios. There are attempts to clarify the relationship between the matrix and the nutrient requirements, as well as questions about the interpretation of the matrix equation.
Some participants provide guidance on how to approach the problem using the inverse matrix, while others express uncertainty about the steps involved in solving for the vector x. The conversation reflects a mix of understanding and confusion regarding the application of matrix operations in this context.
The original poster has provided an inverse matrix but is unsure how to proceed with the remaining parts of the problem. There is an emphasis on the need to solve for specific nutrient amounts using the matrix equation.
uselessjack
A nutritionist is studying the effects of the nutrients folic acid, choline, and inositol. He has three types of food available, and each type contains the following amounts of these nutrients per ounce:
a) Find the inverse of the matrix
and use it to solve the remaining parts of this problem. A calculator may be used.
1) How many ounces of each food should the nutritionist feed his laboratory rats if he wants their daily diet to contain 23 mg of folic acid, 28 mg of choline, and 27 mg of inositol?
2) How much of each food is needed to supply 20 mg of folic acid, 24 mg of choline, and 21 mg of inositol?
3) Will any combination of these foods supply 6 mg of folic acid, 8 mg of choline, and 13 mg of inositol?
A * A^-1 = Identity
I have only been able to yield the inverse of the matrix:
0 1 -1
-3 5/2 0
2 -5/2 1I do not know how to approach the rest of the problem!
For a, you want to solve the matrix equation Ax = y
[tex]\left[ \begin{array} {c c c } 5 & 3 & 5 \\ 6 & 4 & 6 \\ 5 & 4 & 6 \end{array} \right]\left[ \begin{array}{c}x_1\\x_2\\x_3\end{array} \right] = \left[ \begin{array}{c}23\\28\\27\end{array} \right][/tex]
Using your inverse, A-1, can you figure out how to solve for the vector x?
For b, similar setup, but the vector on the right uses the three values of this part of the problem.
Thank you very much, but I'm not sure I understand.
Would I solve for x by setting up the equation "5x + 3y + 5z = 23" and solving?
No. In the matrix equation I showed, the 3 x 3 matrix is A, the column vector in the middle represents the amounts of foods A, B, and C, and the column vector on the right represents the desired amounts of folic acid, choline, and inisotol.
If A is an invertible matrix, then the equation Ax = y can be solved by multiplying the left and right sides by A-1.
Ax = y
==> A-1Ax = A-1y
Why do you think they asked you to find the inverse?
Ah, I see now! Thank you very much for your time and help. I was finally able to find the answers!
  • · Replies 18 ·
  • · Replies 19 ·
11K
