Charge of a segment of an infintely long wire
  • Thread starter Thread starter Linus Pauling
    Charge Wire
The discussion focuses on calculating the charge on a 1.0-cm-long segment of an infinitely long charged wire, given an electric field of 1900 N/C at a distance of 5.70 cm from the wire. The relevant formula used is E_line = (1/4*pi*epsilon) * (2*lambda/r), where lambda represents charge per unit length (Q/L). A participant initially miscalculated the charge due to potential errors in unit conversion or arithmetic, but was reassured that the values for distance and length were correct.
  • Understanding of electric fields and their calculations
  • Familiarity with the concept of charge density (lambda)
  • Knowledge of unit conversions, particularly between centimeters and meters
  • Basic proficiency in algebra for solving equations
  • Review the derivation of the electric field due to an infinitely long charged wire
  • Practice calculations involving charge density and electric fields
  • Learn about unit conversion techniques in physics
  • Explore common errors in electrostatics calculations and how to avoid them
Students studying electromagnetism, physics educators, and anyone involved in electrical engineering or related fields seeking to understand the principles of electric fields around charged conductors.
Linus Pauling
1. The electric field 5.70 cm from a very long charged wire is ( 1900 N/C,toward the wire). What is the charge (in nC) on a 1.0-cm-long segment of the wire?
2. E_line = (1/4*pi*epsilon) * (2*lambda/r), lambda = Q/L
3. Using the above equation, I solved for Q using r = 5.7 cm and L = 1 cm, and got an answer several orders of magnitude off. I assume I am using incorrect r and L values. What, exactly, am I doing wrong?
You're using the right values. I'm guessing you made a calculation error or a unit conversion error.
  • · Replies 17 ·
  • · Replies 21 ·
