Improve Mathematica Output Display: Show Variable Names in Output
  • Context: Mathematica
  • Thread starter Thread starter NeoDevin
    Mathematica Output
The discussion revolves around how to modify Mathematica's output display to include variable names alongside their corresponding values. Participants explore methods to achieve this, particularly in the context of handling multiple outputs efficiently.
  • Homework-related
  • One participant inquires about displaying variable names in Mathematica's output, expressing frustration with tracking multiple outputs.
  • Another participant suggests a custom function, nameAndValue, to print the variable name and its value together.
  • A follow-up question is raised about the possibility of setting this behavior as a default in Mathematica, similar to functionality in Matlab.
  • Discussion includes mention of $Pre and $Post as potential tools for processing outputs, though caution is advised regarding their use.
  • One participant notes that typically, Mathematica outputs a single value per variable and suggests considering alternative coding strategies for handling multiple outputs.
Participants do not reach a consensus on a default method for displaying variable names in outputs, and multiple approaches are discussed without resolution on the best solution.
Limitations include the lack of built-in functionality for default output formatting in Mathematica and the potential risks associated with using $Pre and $Post.
Users of Mathematica who are looking for ways to enhance output readability, particularly those working with multiple variables and outputs in their computations.
NeoDevin
Is there any way to make Mathematica display the variable name in the output?
For example, if I have the following:
Code:
In[1]:= A = 1 + 2 + 3
By default Mathematica outputs this:
Code:
Out[1]:= 6
I would like it to instead output something like this:
Code:
Out[1]:= A = 6
Or in some other way indicate what variable the output value corresponds to. Often times I have large cells with may lines that I want printed out, so I can copy the values into other documents. With the default output, I have to keep track of which line of output corresponds to which variable, which is a nuisance when there are 20-30 lines of output.
SetAttributes[nameAndValue, HoldFirst];
nameAndValue[x_] := Print[Unevaluated[x], "=", x];
a = 4;
nameAndValue[a]
Thanks for the reply, that will do the trick.
I don't suppose there's an option anywhere to make this (or something similar) the default behavior? Like it is in Matlab.
There is $Pre and $Post which can be expressions that process expressions before and after MMA handles them.
That is not without some risk, but MMA help and a search in the right places can find you a few examples of how others have used this.
If you have lots of examples where you have dozens of lines of output for every variable then you might consider whether there might be different ways of coding that do not have this.
Mostly it's just one output for any given variable. For example, in a homework assignment, where they ask for a bunch of values along the way.
Thanks for the help, I'll look into those.
  • · Replies 0 ·
  • · Replies 21 ·
