Finding time and speed at which skydiver hits the ground
The discussion revolves around calculating the time and speed at which a skydiver hits the ground, assuming an initial vertical velocity of zero and a gravitational acceleration of 10 m/s². The problem involves kinematic equations to determine these values under the specified conditions.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to use kinematic equations to find the time to impact and the speed at which the skydiver hits the ground. Some participants suggest using the equation v = u + at to find the final velocity. Others question the validity of the calculated speed, noting it seems excessively high.
The discussion is ongoing, with participants exploring different approaches to the problem. Some guidance has been offered regarding the use of kinematic equations, and there is acknowledgment of the impact of air resistance, which has not been factored into the calculations.
Participants note that the skydiver's parachute fails to open, which would contribute to a higher speed during descent. There is also a mention of the initial height of 4000 meters, which is critical to the calculations being discussed.
andrey21
If initial vetical velocity is zero, at what time and how fast does a skydiver hit the ground? Assume that g=10m.s^-2
Given that:
y' = -gt + A y' is the vertical velocity
y = -(1/2).g.t^2 +At +B y is the distance above the ground
In order to solve how long takes skydiver to hit ground I did the following:
0 = -(1/2).g.t^2 +(0)t + 4000
4000 = -(1/2).g.t^2
8000 = g.t^2
800 = t^2
t = 28.284 seconds!
Now from here I am unsure how to find the speed at which hits the ground. Help needed sorry for bad formatting!
How about using v=u+at?
Okay so if initial velocity is zero I get:
v = 0 +10.28.284
v = 282.84 m.s^-2
Is this correct?
It seems bit excessive as 282.84m.s^-2 is 632.319 MPH. DOes that seem correct to you?
I must also say the skydivers parachute fails to open so a higher speed on descent would be expected.
Anymore ideas please, help desperatley needed!
Looks ok to me if the initial height is 4000m. 282m/s IS fast, but you've completely neglected air friction. That would slow the skydiver down a lot, even if the chute didn't open.
Ah yes thanks for the post :)
  • · Replies 17 ·
  • · Replies 38 ·
