Is an Ideal of Polynomials Without Constant Terms Finitely Generated?
  • Context: Graduate
  • Thread starter Thread starter mesarmath
The ideal of polynomials without constant terms in the polynomial ring Z[x₁, x₂, x₃, ...] is not finitely generated when the ring has an infinite number of variables. This conclusion is established by recognizing that any finite generating set of polynomials can only generate finitely many variables, while the submodule of polynomials without constant terms encompasses countably many variables. The proof relies on the limitation of polynomials having only finitely many non-zero terms, which prevents the generation of an infinite set.
  • Understanding of polynomial rings, specifically Z[x₁, x₂, x₃, ...]
  • Knowledge of finitely generated ideals in algebra
  • Familiarity with the concept of submodules in module theory
  • Basic grasp of the properties of polynomials and their terms
  • Study the properties of finitely generated modules over rings
  • Explore the structure of polynomial rings with infinite variables
  • Learn about the implications of non-finitely generated ideals in algebra
  • Investigate examples of finitely generated ideals in different polynomial rings
Mathematicians, algebraists, and students studying abstract algebra, particularly those interested in polynomial rings and module theory.
mesarmath
hi,
i was reading about finitely generated ideals
and there was a remark that ideal which consists of polynomials with no constant term, in the polynomial ring Z[x_1,x_2,x_3,,,,,,] , is not finitely generated.
and i can not show it is not finitely generated
any idea?
This is only true if the ring R=Z[x_1,x_2,x_3,...] has an infinite number of variables. The ring itself is finitely generated as an R-module by the identity {1}. Clearly we can't use {1} to generate the submodule consisting of all polynomials with no constant term though.
The proof that this submodule is not finitely generated hinges on the fact that polynomials have only finitely many non-zero terms. This means that any finite generating set of polynomials must generate only finitely many variables. The submodule has countably many variables, so cannot be finitely generated.
  • · Replies 21 ·
  • · Replies 40 ·
  • · Replies 25 ·
