Confused about Voltage and Current
The discussion revolves around the relationship between voltage and current, exploring whether they are proportional or inversely proportional in different contexts. Participants examine this relationship through the lens of various electrical components and devices, including resistors, generators, and diodes.
  • Some participants assert that Ohm's law indicates voltage and current are proportional (V=IR), while others mention contexts where they appear inversely proportional, such as with generators.
  • A participant explains that in generators, increasing voltage can lead to a decrease in current to maintain constant power output.
  • Another participant notes that the relationship between voltage and current varies by device, citing examples like resistors (linear relationship) and diodes (exponential/logarithmic relationship).
  • There is a discussion about the definitions of voltage and current, with voltage described as potential energy per unit charge and current as the rate of charge flow.
  • Some participants mention that voltage can exist without current and vice versa, raising questions about the conditions under which this occurs.
  • A participant introduces the concept of superconductors, suggesting that current can flow without voltage in such cases, while also discussing the interdependence of voltage and current in dynamic conditions.
  • Concerns are raised about the time it takes for current to stop flowing after voltage is removed, indicating a need for deeper understanding of electrical behavior.
Participants express differing views on the relationship between voltage and current, with no consensus reached. Some agree on the proportionality in certain contexts, while others highlight exceptions and varying relationships based on the device in question.
The discussion reveals limitations in understanding the conditions under which voltage and current interact, as well as the dependence on specific electrical components. The complexity of the relationship is acknowledged, with various models and equations presented without resolution.
This discussion may be of interest to students and enthusiasts of physics and electrical engineering, particularly those seeking to understand the nuances of voltage and current relationships in different contexts.
FeDeX_LaTeX
Hello;
What is the relationship between the two? Are they proportional or inversely proportional to each other? I ask this because my physics teacher said that they were proportional on one day, then inversely proportional on another day. I thought that more current = more voltage... am I right or wrong?
Thanks.
Ohm's law states that they are proportional, V=IR. In what context did you hear inversely proportional?
Well, the lesson yesterday was regarding generators. He stated that as voltage increased, current decreased (as one goes up, the other must go down). I didn't argue at that point because that confused me (as you said, I thought they were proportional by V=IR).
Your teacher is trying to tell you when they are proportional, and when they are not. In resistors, for example, they are proportional. In transformers, they are inversely proportional.
Regarding generators, the generating power of the generator is (ideally) equal to the product of the current and the voltage it produces, so increasing one means decreasing the other. Therefore you can transmit the equivalent amount of power with higher voltage and lower current or lower voltage and higher current -- if you want to increase both, you need to get a more powerful generator. Maybe that's what your teacher meant.
The relation between the two depends on the device. In a resistor, the relation is linear, i.e. V = I*R, per Ohm's law.
But for a junction diode, the relation ship is exponential/logarithmic. A diode behaves per the equation Id = Is*exp((Vd/Vt) - 1), or Vd = Vt*ln((Id/Is) + 1). Vt = nkT/q, which any reference text can elaborate on.
For other devices, like incandescent light bulbs, another non-linear equation is used.
So in conclusion, the relation between I & V depends on the device and application.
Claude
Voltate is a potential, the potential energy per unit charge within a field, with respect to some reference point, or the difference in potential between two points.
Current is a rate of charge flow. 1 amp is equivalent to 6.24150948×10^18 elemental charges per second. An electron has -1 elemental charge.
Voltage and current only have a relationship when there is current flowing through some type of electrical component, and the relationship depends on that component.
Note that voltage can exist without current.
...and current without voltage.
Lsos - under what conditions do you consider that a current will flow without there being a potential difference across the conductor i.e a Voltage
I'll answer, if it's ok. The answer is - superconductor. But I w/o V, as well as V w/o I, only happens under static conditions.
With dynamic (time varying) conditions, I & V cannot exist independently. They are mutually inclusive, co-dependent, simultaneous, inter-related, etc. One cannot exist w/o the other. This issue is very old, but yet it keeps rearing its head. Current and voltage co-exist, and that is what we know. But because real world power sources, like batteries and generators, are designed and built to operate in the constant voltage mode, many assume that voltage is somehow more basic than current. It is not. Power sources could, and have been constructed for constant current operation. It isn't done because losses are much higher.
The OP asked about the I-V relation. That would depend on the device under examination. Some devices are linear, some are not. That was what I conveyed.
Does this help?
That's what I had in mind, a superconductor.
But also...even if you have a normal wire, doesn't it take some finite time for the current to stop flowing once you remove the voltage?
I'm not so sure how electricity works at this deeper level, but it makes sense to me that it would not be instantaneous, and would depend on the resistance...
  • · Replies 25 ·
  • · Replies 23 ·
  • · Replies 16 ·
