Magnetism in infinite conducting slab
The discussion revolves around a problem involving magnetism in an infinite conducting slab with a uniform current density. The original poster presents multiple questions related to the magnetic field, forces, and charge flow in a loop situated above the slab.
  • Participants discuss the applicability of Ampere's Law for determining the magnetic field and consider various methods for integration. Some express uncertainty about handling the complexity of the problem due to the geometry of the slab.
There are attempts to explore different approaches to the problem, with some participants suggesting the use of Ampere's Law. However, there is no explicit consensus on the best method to proceed, and uncertainty remains regarding the initial steps.
Participants note the challenges posed by the infinite extent of the slab and the complexity introduced by the loop's position and current. There is also mention of the resistance of the wire used in the loop, which may affect the analysis.
daveed
"a conducting slab has infinite extent in the x and y directions and thickness L in the z direction. The slab is centered at z=0 and carries a uniform current density J=Ji where i, j, and k are unit vectors in the x, y, and z directiosn."
-Find the magnetic field B at all points.
-A square loop of side a is placed distance b above the slab. The loop has unit normal vector n=sin(q)i+cos(q)j and applied current J. what is the net force and net torque to the loop as a function of q?
-the applied current I is now removed from the loop and the current density in the slab J=Ji is reduced to zero over time T. The wire used to construct the loop has resistance/unit S. How much charge flows through each cross section of the loop wire due to the reduction in current density.
What have you tried so far?
It seems to me ampere's law would work well in determining the magnetic field; use a square loop such that you know exactly how much current passing through it and the only field is at the top and bottom. Integrating a line of wires across the surface and then again through the depth is another option, but sounds horrible to me.
Once you have the magnetic field, the second part should come together easily enough.
i really don't know how to go about doing this when its not a single wire... sorry =(
Have you considered the integral form of Ampere's Law?
  • · Replies 0 ·
  • · Replies 25 ·
