The force conversation of angular momentum creates
The discussion revolves around the concepts of angular momentum, forces acting on a spinning body, and the behavior of gyroscopes. Participants explore the implications of pulling a wire on a spinning object and the forces involved, as well as the mechanics of gyroscopic stability and precession.
  • One participant questions how the speed of a spinning body increases when a wire is pulled, suggesting that the force of the wire cannot do work as it is perpendicular to the velocity.
  • Another participant argues that if the object is being pulled in, the force of the wire is not perpendicular to the velocity and therefore does work on the object.
  • A participant expresses confusion about the initial conditions of the force being perpendicular and relates this to the behavior of gyroscopes.
  • Participants discuss why a gyroscope does not fall despite gravitational force acting on it, attributing this to the presence of a normal force at the pivot that balances the weight.
  • One participant notes that while the net force is zero, the net torque is not, explaining that torque arises from the weight and the position of the center of gravity, leading to gyroscopic precession.
Participants express differing views on the nature of forces acting on the spinning body and the implications for gyroscopic motion. The discussion remains unresolved regarding the initial conditions of force application and the relationship between force and torque.
There are unresolved assumptions regarding the definitions of forces and torques in the context of spinning bodies and gyroscopes. The discussion also highlights the complexity of the interactions at play in these scenarios.
Mad_Eye
A body is tied to a wire that go through a hole in a (frictionless) table on which the body is spinning.
The body is spinning while the wire is pulled from beneath the table.
according to conversation of angular momentum the speed of the body should now increase, but in terms of forces... what force is actually increasing the speed? the force of the wire can't do it since it perpendicular to the velocity, (thus not doing any work, and thus the kinetic energy should be the same).
so what force is doing it, and where does it comes from in the atomic level..?
Thank you
If the object is being pulled in then it is not moving in uniform circular motion and the force of the wire is, in fact, not perpendicular to the velocity and therefore does work on the object.
:mad: damn, I actually thought about it, and some why deny it..
because seemingly in the first infinitesimal moment it still perpendicular.
so what about gyroscope, that stand still in unnatural way
http://t2.gstatic.com/images?q=tbn:...aviddarling.info/images/gyroscope_diagram.jpg
you have mg pulling it down, why doesn't it fall?
It does not fall down because at the pivot there is also a normal force equal to mg pushing it up. So there is no net force in the vertical direction.
but.. what?
the net torque is not zero..
and what the different between a spinning gyro and a non spinning..?
Force and torque are different. The net force is 0, the net torque is not zero.
The torque is the cross product of the weight (down) and the vector from the pivot to the center of gravity. This vector is in the horizontal direction, and therefore the angular momentum changes in that direction which causes the gyroscope to precess.
  • · Replies 60 ·
  • · Replies 23 ·
  • · Replies 36 ·
16K
  • · Replies 29 ·
